06 srx evap question
Results 1 to 3 of 3
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 06 srx evap question in Cadillac SRX / XT5 Forums; Where can i find a diagram of the evap systemfor 06 srx... i need to change the solenoid valve as ...
    martin11581 is offline Cadillac Owners Member
    Automobile(s): 2006 SRX
    Apr 2013
    1
    Cool06 srx evap question
    Where can i find a diagram of the evap systemfor 06 srx... i need to change the solenoid valve as per what i have been reading but i was not able to find on how to do it. Where is the part located? Any references would be of great help!
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,799
    Re: 06 srx evap question
    There are 2, the easy one is on top of engine, I believe rt. side. The other is on the canister, a btch to get to, ahead or lf. rear wheel up under body by gas tank. Make sure that's what you need to do before tackling it, manual says need to drop rear subframe. Do you have DTCs?
    Been fixin' cars for 74 years
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    If its the purge solenoid this is how you remove its on top of the passenger valve cover. 2 4 18mm bolts to remove the strut brace take oil and power steering caps off and remove the engine cover 1 10mm holds the solenoid down and has two lines with quick disconnects should take more than an hour tops. Usually can tell its bad when there is a rapid clicking under the hood
