Turn signal is crazy
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Turn signal is crazy in Cadillac SRX / XT5 Forums; The left turn signal in my SRX is acting like it needs the bulb replaced. I changed the bulb as ...
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,224
    The left turn signal in my SRX is acting like it needs the bulb replaced. I changed the bulb as well as the socket and I still have the problem. Anyone else have this happen? I had a red squirrel do some damage to the insulation under the hood and I fear that he messed up something else. I hope this is a common problem with a fix.
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    Re: Turn signal is crazy
    What exactly is the turn signal doing?
    Sep 2003
    NY
    1,224
    Flashes quickly like the bulb is going bad.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Is it the back?
    Whiplash_89's Avatar
    Whiplash_89 is offline Cadillac Owners Fanatic
    Automobile(s): 04 SRX V8 AWD, 04 NSRT4
    Nov 2012
    Windsor, ON
    223
    Front or rear? Do they function properly even though it acts as if they do not?
    Sep 2003
    NY
    1,224
    Kind of late on the response, I forgot that I posted a questions about this. The quick flashing happens on both the front and the back. The front is where I changed the bulb and the socket.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,830
    Still having problem? If so, do bulbs work? Brake light(same as flasher)? If front bulb is out, whole side flashes rapidly. Does hazard flasher work, both sides, front and rear? That would show bulbs good. If so, flasher module is bad.
    Been fixin' cars for 74 years
    Sep 2003
    NY
    1,224
    Looks like a bad flasher module. The hazard lights all flash correctly. Does anyone have a part number?
  11. Remove Advertisements
