Rubbing and chatter from rear end question...
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree6Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Rubbing and chatter from rear end question... in Cadillac SRX / XT5 Forums; I have read the previous threads on this rather common issue. So we are going to drain the fluid and ...
    AmyinFL is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac SRX V6
    Apr 2013
    14
    QuestionRubbing and chatter from rear end question...
    I have read the previous threads on this rather common issue. So we are going to drain the fluid and put in the LS fluid from the dealer as recommended. However, my husband wants to add the LS lube additive as well (4oz bottle). What's your thoughts experience with this? Thanks in advance!
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,835
    Re: Rubbing and chatter from rear end question...
    If you have a limited slip differential, the additive is a must. If you don't have LS, you've got a different problem.
    AmyinFL and AmyinFL like this.
    Been fixin' cars for 74 years
    Apr 2013
    14
    @ glake89-How do I know if I have LS? Thanks!
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,835
    Look for RPO G80. The option list is on a label either on the under side of the jack compartment lid or one of the rear cubbies.
    Apr 2013
    14
    Thank you! Looks like all 07' V6 Caddy SRX RWD are equipped with LS Diff. I sure am hopping this oil change an additive do the trick! I know it can take a little time once changed...I will report back.
    Quote Originally Posted by glake89 View Post
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,835
    Change should be almost immediate.
    Apr 2013
    14
    Ok, just waiting on the additive to arrive, and then we will change it out Thanks again!
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,023
    The limited slip differential is not a standard feature on all SRX's. LSD was standard on all V8 vehicles (AWD or RWD) and optional on all V6 vehicles. In addition, if you have the Sport Package, you will also have LSD.
    Apr 2013
    14
    Thank you.. 08SRX.... I am going to check it out. I looked up the VIN and it says it does have LS...but I want to be sure..
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    800
    Check out post #4. http://www.cadillacforums.com/forums...erentials.html
    According to the shop manual a full 4 oz isn't needed depending on how the lub is drained. Probably won't hurt anything using the full 4 oz but GM apparently thinks it isn't needed.
    Apr 2013
    14
    Still can't find the RPO sticker....
    Jan 2007
    800
    Quote Originally Posted by AmyinFL View Post
    On my 07 it's in that rear compartment that holds your jack. If you aren't familiar with what they look like I found several typical examples by searching "Cadillac rpo list" in google or bing Images. You'll see several with G80 in the list
    Apr 2013
    14
    Quote Originally Posted by n7don_srx View Post
    Just went and looked again and found it on the lid of the jack compartment. Didn't look there last time! Thanks! And I DO have a LS. Sure hoping the oil change and additive fix this problem. @ n7don_srx- Have you had this issue with your srx?
  16. #14
    Jan 2007
    800
    No problems here. There was recall a couple years ago to replace the pinion shaft seal with an update version. Was this done on your vehicle? Your dealer should be able to determine if so. Maybe the lub was drained and no friction modifier added. There were line items on the repair order on my 07 showing new lub and the friction modifier had been replaced as part of the recall and seal replacement.
    Your original posting mentions rumbling/chattering...... generally if this happens while turning the friction modifier should fix it. If present while driving in a straight line you may have other issues.
  17. #15
    Apr 2013
    14
    Thankfully it is only while turning, and seems to only do it when it's cold (not outside temp but meaning when car is first driven) I did call the dealer that this vehicle was serviced at and all recalls have been taken care of. Additionally, I requested the records and it shows where a diff. bushing was replaced last year...it does not say anything about the friction modifier additive-so hoping it will do the trick! I just bought this car from an old man last week, and of course on the test drive we didn't hear it! LOL! She is a beauty though..black on black and completely loaded only 58k miles
  18. Remove Advertisements
