Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Helpon the road at garage need advice ASAP!
    orandaberg Guest
    Is the main radiator suppose to look like this, need part number!
    Hose lines need part number
    bracket need part number
    VIN 1GYEE63A370181467
    07, 4,6L SRX
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    809
    Re: Helpon the road at garage need advice ASAP!
    You might have successs browsing this site: http://parts.nalleygmc.com/
    orandaberg Guest
    Thanks
    But is the main radiator suppose to be in this shape thought it would be square
  5. #4
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    How did you attach your fans?
    Are you saying the rad is bend or bowing down, I can't tell from the picture.
  6. #5
    orandaberg Guest
    yes the radiator has a covex shape at the bottom (nearest engine), and is about 1/4" lower in the middle then the front aux radiator.
  7. #6
    Sep 2007
    2,621
    How did you mount your fans???????
  8. #7
    orandaberg Guest
    I did not mount the fans this is a pic from looking at the car after removal of the plastic shield, I am at a garage on the way home, cannot continue, do not want to take the chance. So is the rad suppose to be square or convex at the bottom, the aux rad is square the main is convex at the bottom
  9. #8
    Sep 2007
    2,621
    What I am saying is are the fans mounted to the rad or to the frame of the rad?
  10. #9
    orandaberg Guest
    yes it is
    Its as if the plastic just formed with the convex, in the parts schematic its square
  11. #10
    Sep 2007
    2,621
    Yes it is what?
  12. #11
    orandaberg Guest
    Yes its formed with the covex at the bottom
  13. #12
    Sep 2007
    2,621
    I love you but your killing me!
    I am thinking if the fans were mounted to the rad core they may be too heavy and bent the core down, the OEM fans are mounted to the frame.
    If it has not failed then I would get it home and look more.
    Now I see better, not sure I will look in the parts book and see if it should be roundish.
  14. #13
    orandaberg Guest
    My Transmission coolant tubes as you can see are rotten. Can not risk another 1600 km home so tomorrow we pull off the front end and remove aux.transmission and main rads
    http://www.tonkinonlineparts.com/sho...rimLevel=19237
    looks like parts 7 and 8
  15. #14
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,921
    If it's the transmission cooler lines you're worried about, replace the rusty part with decent hydraulic rubber line and good clamps. There's no significant pressure involved. Then you can get home, and drive for many KMs more without worry.
    Been fixin' cars for 74 years
  16. #15
    Sep 2007
    2,621
    AS stated above, don't use heater hose as EPDM does not play well with ATF.
  • You may not post replies
