Opinions on towing without the tow package, well sort of.
Results 1 to 11 of 11
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Opinions on towing without the tow package, well sort of. in Cadillac SRX / XT5 Forums; So I have an 09 V8 and before I do the complete conversion I wonder if I should just give ...
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    So I have an 09 V8 and before I do the complete conversion I wonder if I should just give it a try and log the results.
    The 09 has the bigger trans cooler and power steering cooler of the V92, I am missing the dual push fans and the engine driven fan (some don't have the engine fan). I have the big single electric pull fan.
    I will be pulling about 3500lbs.
    wrupert is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX N* AWD, 2009 SRX N* AWD, 1986 Buick Grand National
    Aug 2011
    Michigan
    122
    Re: Opinions on towing without the tow package, well sort of.
    You are towing at the max limit, so, keep an eye on the trans and do not tow in OD. I tow a 20 foot open bow boat all over and it tows great with no problems and the 04 did not have the "Tow Package", I just added a hitch and pulled away. The 09 has the trailering button, which basically keeps it out of OD.
    SRX619 is offline Cadillac Owners Member
    Automobile(s): SRX
    May 2012
    Southeastern Massachusetts
    29
    I added the dual push fans and a fan controller to my 04 N* AWD and the setup works well. Retained the stock electric fan as a conversion to the engine mounted unit not mechanically possible. Front of the engine is different. Always runs cool.
    Sep 2007
    2,621
    You know it for a fact that you can't add the fan or you think?
    From what I found it is possible and not hard, I just was not sure I wanted to do it, I don't want to add a fan controller and wanted to let the ECU do it so for me it is kind of all or nothing.
    The other thing is 09 got the bigger trans cooler, all the 09's get the V92 trans cooler.
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    so how feasible is towing a huge uhail trailer full of antique furniture on an 04 awd n* without tow package. what precautions should be taken?
    Sep 2007
    2,621
    Define huge and how heavy?
    Jul 2005
    Fayetteville NC
    33
    4,513
    big enough for a dining room set consisting of:
    solid black oak dinner table with built in extending leaves.
    8 chairs
    buffet piece dont know what its called
    dresser looking thing dont know what its called
    corner piece dont quite know what thats called either.
    its all pretty thick solid wood...though i dont know the exact weight
    Sep 2007
    2,621
    What does the trailer weigh?
    Your only issue is going to be a small trans cooler, that being said you are rated to tow 2000lbs, so if the trailer is that much then use caution and keep your foot out of it. That being said you will need trailer brakes as well so why not just rent a uhaul with a motor and call it a day.
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Is the 4,200 pound Northstar towing capacity only for ones with the tow package option that has the coolers? PJ
    Sep 2007
    2,621
    Yes, 4250 for V6 or V8
    Feb 2010
    New England
    2,005
    Oak. That is easily over 1,000 pounds of furniture. I have an entertainment center, oak, and empty that is 450. PJ
  14. Remove Advertisements
