Transmission fluid indicator on DIC...
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Transmission fluid indicator on DIC... in Cadillac SRX / XT5 Forums; ...is staying at 81%. The last time the transmission was serviced was about 3 years/35-40,000 miles ago. Maybe 50,000. I'm ...
    rdgfx3 Guest
    ...is staying at 81%. The last time the transmission was serviced was about 3 years/35-40,000 miles ago. Maybe 50,000. I'm not sure. I didn't take it to have the service done. The barely human who used to drive it had it serviced at the dealer. My oil life indicator works as it should. The trans indicator hasn't changed in a looooong time. Problem?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Nope perfectly normal i bought mine with 69k and it was at 38 and here i am at 98k and its at 26
    TimRSRX777 is offline Cadillac Owners Fanatic
    Automobile(s): SRX
    Feb 2013
    126
    Re: Transmission fluid indicator on DIC...
    Ours is at 46%. When is it considered prudent to get the transmission flushed and the fluid changed? When it reaches 0?
    Oct 2012
    975
    Recommend at 100k but as a mechanic waiting that long would possibly cause damage if you do flush it cause all the metal particles willbgo shooting through the trans and cause issues down the road. I go by the old school of every 60k miles
    Jim_V is offline Cadillac Owners Fanatic
    Automobile(s): SRX V8 RWD 2004
    Feb 2005
    Pasadena Maryland
    153
    Changed mine at 70000. Dealer said they found that waiting to 100000 proved to be too long.
    Automobile(s): SRX
    Feb 2013
    126
    repnatl, as a mechanic then, do you recommend a flush? If you are saying that you think a flush could damage the transmission? Maybe just a drain fluid and refill? How is the transmission fluid life system reset?
    Oct 2012
    975
    That's just what I've heard when i was working in several shops personally I've never done a flush on my own vehicles just a drain and fill and I've never had any long term issues but doing that means that on average 4 qts or more of old fluid will still be in the torque converter. You should be fine just most shops won't do a flush on higher mileage vehicles for that risk factor. Its reset the same way the olm is within the dic menu.
    orandaberg Guest
    Does the DIC show oil or transmission %.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,947
    Just oil%
    Been fixin' cars for 74 years
  12. Remove Advertisements
