Canister Vent Valve Solenoid
Results 1 to 15 of 15
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Canister Vent Valve Solenoid in Cadillac SRX / XT5 Forums; Can anyone tell me location of the Canister Vent Valve Solenoid that is by the gas tank I just cant ...
    drod777 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6
    Oct 2012
    24
    56
    QuestionCanister Vent Valve Solenoid
    Can anyone tell me location of the Canister Vent Valve Solenoid that is by the gas tank I just cant seem to find it i'm prob overlooking but any idea where about??
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,879
    Re: Canister Vent Valve Solenoid
    It's near the right rear of the engine on top of the engine. Need to remove the cover to locate.
    Been fixin' cars for 74 years
    Oct 2012
    24
    56
    Quote Originally Posted by glake89 View Post
    But there is one by the gas tank right
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Well from the response he gave I would say no, he did not say there were two.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,879
    The canister is back there (by the tank) but not the valve.
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    The Purge solenoid is in the engine compartment, the Vent Valve solenoid is on the canister.
    Oct 2012
    24
    56
    Quote Originally Posted by rlh6805 View Post
    Ok well I need to change the solenoid and I guess im looking over the canister because I can not find it
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,879
    Sorry, sent you to the wrong place. The vent valve is a twist to remove but to get to the canister you have to remove the rear frame (per SM). That involves the exhaust, rear prop shaft, shocks, brake lines etc. etc., over 20 steps. Maybe some real skinny arms might work. Better make real sure that is what needs replacing before starting this project.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,879
    Here's a shot of what you're looking for-
    Oct 2012
    24
    56
    Yeah that's all I needed was the Vent Valve not the canister
    What do I need to remove to find this. Is that the spare tire or no
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,879
    That's the SM drawing of the end of the canister after the rear frame has been removed. I think it's forward of the fuel tank towards the left side. Again, why do you think you need to replace it?
    Oct 2012
    24
    56
    Well after I put gas and have replaced the gas cap, the car don't start. after 2 times starting, there are no more issues starting but just a rough idle, its only when I put gas, I have taken the gas cap off and never replaced and it turns on and not as rough of a idle. So I'm just lost now
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,879
    So, if you get gas and replace the gas cap, it won't start but after a couple tries it will? Then starts OK until you get gas again but has a rough idle. If you leave the cap off after getting gas, it starts and idle is not as rough? Please confirm all or part of this so we can help.
    Also, when you fill the tank, do you stop when the pump first shuts off or do you keep adding until it won't take any more? VERY IMPORTANT!
  16. #14
    Oct 2012
    24
    56
    Ok everything you have said is correct the idle is just not as rough as when the cap is put back on, And no I never fill it up the tank to the max always half or almost full.
  17. #15
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,879
    Have you checked for DTCs , pending or history? If not, do. If you have a fuel pressure gauge, Hook it up and check pressure when it won't start. A short to voltage in the signal circuit of the CKP sensor will prevent starting and not set a DTC. Leaking injectors can flood the engine. An easy check would be to inspect and test all the vacuum and similar lines for continence, considering the age of the car.
    Let's keep after this until we get it.
  18. Remove Advertisements
