siren in rear when battery low?
Results 1 to 12 of 12
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, siren in rear when battery low? in Cadillac SRX / XT5 Forums; Hello I have had 2 batteries, one the dealer replaced when he sold me the car, the second I bought ...
    orandaberg Guest
    Hello
    I have had 2 batteries, one the dealer replaced when he sold me the car, the second I bought because it would not hold a load. I have tested for battery drain, I do show some drainage, removed radio fuse, the same, removed connections to my radar and rear headrest DVD, sane drain, removed every fuse under the hood same drain, the battery will only last 5 days without a charge. So every time I leave the car over 3 days I keep a trickle charger, or remove the ground if I leave at the airport.
    I was wondering what is the siren noise in the rear of the car when the battery is low and needs a charge? Hook up the charger and a siren goes on at the right rear, sort of like a break in alarm, it also looks like the battery only lets itself get to a point of drainage where it stops draining the battery. If I hook up a charger it takes an hr and the car is good to go for daily driving. As long as the car is driven everyday or before3-5 days are up it starts fine. Any ideas. Seems to be a problem with every SRX I wanted to test drive, they always had to re charge the battery before I could drive it (5 cars tested).
    orandaberg Guest
    Re: siren in rear when battery low?
    Nobody has heard this sound?
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    You sub woofer is back there, is it possible that the amp is powering it all the time for some reason?
    You installed a bunch of aftermarket stuff in a very short time so it could be anything, the way the car talks to other parts of the car means that two unrelated things could cause issues that don't make any sense. Not saying its an aftermarket item but im just saying.
    orandaberg Guest
    Thanks
    I will have to pull the fuses in the back, but what a hassel to remove trim panels! How about that siren going off when charging the battery, is that some kind of alarm that goes off when the battery is at a level is going to be to weak?
    Sep 2007
    2,621
    I think you missed what I was saying.
    Stuff in the back may be powered by stuff in the front, so Im not saying pull fuses, find out what is making the noise first like the sub.
    I don't know of any alarm for battery level.
    orandaberg Guest
    AHHH SOOOO ok. So next time I run into this I should pull the radio fuse, would that be enough to stop power to the sub wof in the back. The sound is coming from the right rear panel, the sound lasts for about 5 mins before going off on its own when charging
    Sep 2007
    2,621
    I think the amp fuse is for the amp.
    You could also try pulling the plug on the sub and do it that way, easy to get at from the back.
    JayT F1's Avatar
    JayT F1 is offline Cadillac Owners Member
    Jun 2012
    73
    I had a Power Capacitor wired in with a Sub woofer in another car. Whenever there was loss of power from the battery, the Cap would alarm on 'low voltage' until in either a) ran out of power b) was re-charged from the cars 12v supply
    Do you have some sort of Cap or auxiliary power to your amplifier / sub?
    orandaberg Guest
    Not that I know of, its OEM, the sound is similar to a cars alarm when you tamper with it, not a honking horn, just a high pitch whistle sound
    Tiger1106 is offline Cadillac Owners Fanatic
    Automobile(s): SRX'05 4.6L
    Jul 2014
    235
    It's not connected to the sub - this siren even goes on with the battery cables disconnected! It has its own battery. And it continues for 10 min. and nothing seems to be able to stop it. Is it only an export version problem?
    Anybody knows what it is?
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    @Tiger...sorry...I've got no solution for the problem...but, yes...it's an export version problem...
    ...the siren is an export specs part...part of the export specs vehicle anti theft/theft deterrent system...export SRX, STS, CTS 1+2, some of the export Corvette C6 and some other cars...they all get this siren...
    ...and iirc...I once read about a similar problem with this part in a german vette forum...
    ...all I know is that the siren is making some problems when the little (not changeable) battery pack inside the siren is dying...
    Jul 2014
    235
    Ok, will try to find a fuse for it.
  15. Remove Advertisements
