Torque soec for rear upper control arm bolt?
Results 1 to 3 of 3
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Torque soec for rear upper control arm bolt? in Cadillac SRX / XT5 Forums; I read its 15 ft/lbs then turn 210 degrees. Is this correct? Seems like a low torque....
    subzero32 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX
    Oct 2012
    Valdosta GA
    35
    108
    rdgfx3 Guest
    Re: Torque soec for rear upper control arm bolt?
    From my Alldatadiy] subscription:
    Rear upper control arm.
    Tighten the upper control arm to knuckle nut to 20 Nm (15 ft. lbs.) plus an additional 210 degrees.
    Tighten new upper control arm to frame bolts to 150 Nm (111 ft. lbs.).
    Tighten new upper control arm to frame nuts to 150 Nm (111 ft. lbs.).
    Oct 2012
    Valdosta GA
    35
    108
    Thanks! It just seemed low.
