Opinions on re surfacing rear rotors.
Results 1 to 15 of 15
Like Tree1Likes
  • 2 Post By conedoctor
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Opinions on re surfacing rear rotors. in Cadillac SRX / XT5 Forums; I noticed my rear rotors have a score In Them from worn pads. I was thinking of just resurfacing them. ...
    subzero32 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX
    Oct 2012
    Valdosta GA
    35
    108
    I noticed my rear rotors have a score In Them from worn pads. I was thinking of just resurfacing them. Any thoughts?
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Re: Opinions on re surfacing rear rotors.
    Garbage, buy new.
    Really not worth the time and effort and the trip to the store to get them turned.
    If the score is not wide then don't even worry about it, if by score you mean the rotor face is a mess and all torn up then toss it.
    Kipp and Kipp like this.
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,037
    It depends largely on the remaining thickness of the rotors. If they are thick enough, just replace the pads. A simple score does not diminish braking power by much. If the rotors are worn too much, turning them may bring them below acceptable spec, in which case you would need to replace them.
    Oct 2012
    Valdosta GA
    35
    108
    Can anyone post the minimal thickness of the rotors?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,870
    24mm
    Been fixin' cars for 74 years
    Oct 2012
    Valdosta GA
    35
    108
    Quote Originally Posted by glake89 View Post
    24mm
    Thanks Glake89. I'll measure it with my digital caliper later today. I also ordered OEM front and rear pads just to do them while I'm in there replacing some wheel bearings. The rear pads were very close to no pad material left on the inside of the rotor.
    Sep 2007
    2,621
    Remember to sand the rotor so the new pad can bed in correctly.
    Oct 2012
    Valdosta GA
    35
    108
    Quote Originally Posted by conedoctor View Post
    Good tip, thanks.
    Sep 2007
    2,621
    Don't abuse them right from the get go, do some nice slow downs then some harder slow downs and then let cool and enjoy. Don't come to a complete stop when hot and don't over heat.
    Oct 2012
    Valdosta GA
    35
    108
    So I have 25mm thickness on the rear rotors. Should be good for a while longer I guess.
    08SRX's Avatar
    Jun 2011
    1,037
    Subzero32, if you have 25mm now and the minimum thickness is 24mm and you decided to have them turned, you would need to replace them pretty much immediately. If you just get the pads, you may get a bit more time out of them.
    Jim_V is offline Cadillac Owners Fanatic
    Automobile(s): SRX V8 RWD 2004
    Feb 2005
    Pasadena Maryland
    153
    My brakes have been driving me nuts with a pulsation for a while. Replaced all four rotors and pads and feels great. Don't waste your time resurfacing as these are heavy powerful vehicles that eat up brakes.
    johns12 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8
    Nov 2010
    147
    Quote Originally Posted by Jim_V View Post
    That lower bolt will come out with the right extensions and a lot of patience.
  16. #14
    Oct 2012
    Valdosta GA
    35
    108
    The lower bolt was a challenge but only took 10 min with some good extensions and u joints.
  17. #15
    08SRX's Avatar
    Jun 2011
    1,037
    If your brakes are pulsating, it is likely that one of the rotors is warped. Only way to resolve that one is to replace it.
  18. Remove Advertisements
