Loud clunk in suspension during slow left turns
Results 1 to 10 of 10
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Loud clunk in suspension during slow left turns in Cadillac SRX / XT5 Forums; Now that the weather has warmed up, my SRX has developed a clunking /creaking sound when making slow speed right ...
    08SRX's Avatar
    08SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    992
    Now that the weather has warmed up, my SRX has developed a clunking /creaking sound when making slow speed right (not left) turns while the brakes are applied. Today it did it again, when I backed up there was a pretty loud clunk almost as if steering is binding somehow. The sounds come from the left front but not near the wheel. There are no noises during normal driving, not even when going over bumps. Any ideas what this could be?
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,783
    Re: Loud clunk in suspension during slow left turns
    Your right turn reverse clunker has come loose. Try to repeat it with someone out of the car to better isolate the source.
    Been fixin' cars for 74 years
    08SRX's Avatar
    Jun 2011
    992
    It doesn't appear to do it on flat ground, but only when the vehicle front right is lower that the rest of the vehicle. I will try and see if I can isolate it better. Has anyone else experienced this? Any other ideas?
  5. #4
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,783
    Loose caliper?
  6. #5
    08SRX's Avatar
    Jun 2011
    992
    No, it is definitely not coming from the brakes. It sounds more like a suspension thing.
  7. #6
    xboxman72 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX4 V8 Sport Package
    Aug 2012
    44
    56
    I had an issue with creaking in the front; sounded like a suspension issue but the noise was coming from a broken motor mount.
  8. #7
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,663
    08SRX, I hope the forum feedback has been helpful so far! I realize you're seeking DIY opinions, but please do let me know if you would like me to look into your concerns further at any point and/or schedule a dealership appointment on your behalf. I'm reachable via private message!
    Best,
    Katie
  9. #8
    08SRX's Avatar
    Jun 2011
    992
    Update: The issue appears to have gone away, so Glake may be correct. I am now thinking a brake caliper got stuck and then released. Time will tell.
  10. #9
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    61
    1,096
    Glad to hear your issue resolved itself...
    In the meantime.. don't make any more slow right hand turns!
    Only FAST ones!
  11. #10
    bwilkins750 is offline Cadillac Owners Member
    Automobile(s): Escalade ESV
    Jul 2011
    44
    I took my SRX in for the LCA replacement (squeking when cold outside), and after we got the vehicle back we noticed a clunk noise in the frontend while we were on vacation. I assumed it was nothing, but it got worse as we put more miles on it. When braking, you could hear a single clunk, then when going over bumps it would do it. They had already replaced the sway bar bushings, end links, passenger side LCA, and done an alignment .
    After I thought about the work that was performed at the Dealer, I checked behind there work, and "What do ya know", the Upper control arm bolt was loose enough to tighten by hand and a bolt on the bottom (subframe?) was loose. I had $1000+ worth of work done on the front end suspension and they left two bolts loose. This could have ended up really bad. We had only put about 3k miles on the vehicle since the work was done.
  12. Remove Advertisements
