One Xeon headligt is stronger than the other
Results 1 to 3 of 3
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, One Xeon headligt is stronger than the other in Cadillac SRX / XT5 Forums; As the topic says. One of my headlight is stronger than the other. Why is it like this? I have ...
    davieboiii is offline Cadillac Owners Member
    Nov 2012
    29
    21
    As the topic says.
    One of my headlight is stronger than the other. Why is it like this? I have tried switching place on them if one of them is faulty. But both is working fine.
    Anybody that know what i need to do to fix this issue?
    // David
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,037
    Re: One Xeon headligt is stronger than the other
    Perhaps it is on its way out. You should always replace these in pairs, as older and newer bulbs look very different.
    nayef is offline Cadillac Owners Member
    Automobile(s): '06 SRX LY7 Lux/Full option.
    Mar 2012
    Bahrain
    23
    6
    To Diagnose the problem more details are needed, could be the ballast or just with different bulb age colors change.
    So when you switched the weak bulb with the bright bulb did that side become bright? and did the bright bulb put in the weak side become weak?
    (PS: Asking because my ballast burnt out it started as one bright light and one weak light, then progressed into flickering, then bulb died. It was the ballast for me)
