P0650 Code
Results 1 to 14 of 14
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, P0650 Code in Cadillac SRX / XT5 Forums; I am at the end of my rope with this so I am hoping someone can help me with this. ...
    MyRedSRX is offline Cadillac Owners Member
    Automobile(s): SRX
    Feb 2013
    33
    7
    P0650 Code
    I am at the end of my rope with this so I am hoping someone can help me with this. My MIL light came on 2 weeks ago with code P0650 (right before I need a state inspection) shortly after starting. After about a half a mile of driving it turned itself off. After a few minutes more it started flashing. This has continued each time I driven the car since. I have gone through and checked the fuses and relays, reset the light only for it to come right back on. I have checked the PCM connections, they look fine, is there something more I can do here? Any helps, tips, tricks, procedures would be greatly appreciated. Thanks
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,787
    Re: P0650 Code
    This is what causes code 650, per the SM-
    The ECM detects an open, a short to ground, or a short to voltage on the circuit that controls the MIL.
    So, try wiggling the connector at the ECM and the connector to the dash (harder to get to). If it's not a poor connection, you may need to chase down a possible short to ground/voltage. We can help with that.
    Been fixin' cars for 74 years
    Automobile(s): SRX
    Feb 2013
    33
    7
    Re: P0650 Code
    Thank you for the input. I have already checked the connection at the PCM and it was solid. I checked the instrument cluster last night after your post. It to was a solid connection and did not feel loose at all. I have a DMM but not sure where to start chasing down shorts. Any help would be greatly appreciated. Thank you again.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,787
    Re: P0650 Code
    for starters, the MIL control circuit is a BN/WT wire at the IP connector and at the ECM connector. Disconnect both connectors and test if wire is shorted to ground. If not, turn ign. on, engine off and test again and then test for voltage. Now I've got a foot and a half snow to clean up on a 1/2 mi driveway, then I'll check back.
    Automobile(s): SRX
    Feb 2013
    33
    7
    Re: P0650 Code
    Thanks for the start, I will not be able to do it for a few hours (still at work) but I will report back. I would not think the light would come on at all or flicker if I was shorted to ground (I also know I may be dead wrong). I would assume if the voltage is different at the IP than at the PCM I would have to replace one of those components depending on which one has the proper voltage. In that case I hope for the IP (although being wrong about the short and replacing a wire would be awesome) otherwise I have to go to the dealer because they have to program a new PCM. Thanks again, a lot, for the insight.
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,666
    Re: P0650 Code
    MyRedSRX, I'm looking forward to your updates! It's great that the community could help you out with your DIY troubleshooting, and please email me anytime if you decide to involve your dealer and would like further assistance. (I'm reachable via email at Katie_Lucille@gmexpert.com!)
    Best,
    Katie
    Automobile(s): SRX
    Feb 2013
    33
    7
    Re: P0650 Code
    Very appreciated Katie, thank you. The dealer I have dealt with in the past has always been very good so I don't anticipate a problem there if it gets to that point.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,787
    Re: P0650 Code
    The way the circuit works is there is always (with key on) power to the MIL light. When called for, the ECM internally grounds the circuit via the BN/WT wire, turning on the lamp.
    Automobile(s): SRX
    Feb 2013
    33
    7
    Re: P0650 Code
    I tested for the short to no avail. Turned the key on and dramatic voltage difference between IP and PCM. Almost nothing at the PCM, I am thinking thats where my problem lies. Any thoughts? Thanks.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,787
    Re: P0650 Code
    Did you test for short with both connectors disconnected, therefore only testing the wire?
    What terminals (or wire color) did you test for voltage and were the connectors attached or still disconnected? What voltage did you get and where?
    Automobile(s): SRX
    Feb 2013
    33
    7
    Re: P0650 Code
    Yes, I tested for the short with both wires disconnected. I tested for voltage with the connections in place. I got 0.3 V at the PCM and 11 V at the IP.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,787
    Re: P0650 Code
    It sounds like a short to voltage. Here are 2 tests. First, check for voltage in the wire with both connectors disconnected.
    Second, make up a 3A fused jumper wire. With only the ECM connector disconnected, connect the jumper to the wire and the ECM case, then turn on ign. Does the mil. light or fuse blow?
    Note: the way you tested you got feed through from the indicator lamp.
    Automobile(s): SRX
    Feb 2013
    33
    7
    Re: P0650 Code
    Glake89, thanks for more ideas man. I can't tell you enough how much this helps. I will try this as well. Do you mean "Does the MIL light up or does the fuse blow". I am slightly confused by the last statement but I am assuming that is what you mean.
  16. #14
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,787
    Re: P0650 Code
    Either one could happen.
  17. Remove Advertisements
