Passenger heated seat does not work.
Results 1 to 5 of 5
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Passenger heated seat does not work. in Cadillac SRX / XT5 Forums; So recently the passenger heated seat stopped working. When I push the button the indicator light of high/low does not ...
    subzero32 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX
    Oct 2012
    Valdosta GA
    35
    108
    So recently the passenger heated seat stopped working. When I push the button the indicator light of high/low does not come on. I changed the 10A fuse located under the rear passenger seat to no avail. Anyone know where to go from here?
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,879
    Re: Passenger heated seat does not work.
    Here's the start from the SM-
    Turn OFF the ignition.
    Disconnect the heated seat module connector C1.
    Turn ON the ignition, with the engine OFF.
    Measure the voltage from the battery positive voltage circuit of the heated seat module to a good ground.
    Does the voltage measure within the specified range?
    10-15 v
    Measure the voltage from the battery positive voltage circuit of the heated seat module to the ground circuit of the heated seat module.
    10-15 V
    Measure the voltage from the ignition 3 voltage circuit of the heated seat module to a good ground.
    10-15 V
    The module is under the seat near the right front.
    Pin
    Wire Color
    Circuit No.
    Function
    A
    RD/WH
    2440
    Battery Positive Voltage
    B
    BN
    41
    Ignition 3 Voltage
    C
    L-BU/WH
    181
    Heated Seat Control Module Status Signal
    D
    Not Used
    E
    PK
    1501
    Driver Heated Seat High/Low Signal
    F-J
    Not Used
    K
    BK
    550
    Ground
    Do that and report back. You will be graded on effort.
    Been fixin' cars for 74 years
    Oct 2012
    Valdosta GA
    35
    108
    So it turns out both heating elements are out and need to be replaced as diagnosed by the dealership while it was in for another power steering pump swap! (thats a long story in itself). They want $130 for the parts and $275 for the labor. I will order both heating elements off of GMpartsdirect for way cheaper and take apart the seat myself. I have read a few tutorials on non SRX caddys but figure its not much different. Wish me luck!
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    $275 is not bad, guess it depends on what your free time is worth and how much you have.
    I do some things but other stuff I am more than happy to just drop it off.
    Can't be that hard to get the heaters out and back in, how do the seat covers come off?
    Oct 2012
    Valdosta GA
    35
    108
    If I do it myself it will cost me $80 which enough savings for me to do it vs about $400 total at the dealership.
  8. Remove Advertisements
