2004 SRX passenger low bean HID keeps going out
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2004 SRX passenger low bean HID keeps going out in Cadillac SRX / XT5 Forums; my passenger low bean HID went out. I took it got it replaced drove it to the garage and that ...
    joshkel2004 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX
    Jan 2013
    3
    my passenger low bean HID went out. I took it got it replaced drove it to the garage and that night it was out again. I took it back to the place and they said they would replace it one more time. They did and later that night it went out again. There is moisture in the headlight casing but at 100.00 a light I don't want to take it to the dealership yet. Anyone run into this before. What can I try? Any ideas?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Fyi you can get 2 of those stock hid bulbs with free shipping for around $40 on ebay. Could have a bad ballast.
    Jan 2013
    3
    Re: 2004 SRX passenger low bean HID keeps going out
    thats what I'm thinking but dealership was like usually it wouldn't blow the bulbs it would just stop them from working and of course they want me to bring it in
    is there anyway to test the ballast?
    nevermind I can just move them from one side to the other.
    Oct 2012
    975
    Just what I was gonna suggest try the other side. Cause our bulbs are so easy to change lol. But true usually they don't blow just stop working.might have a bad ground.
    nayef is offline Cadillac Owners Member
    Automobile(s): '06 SRX LY7 Lux/Full option.
    Mar 2012
    Bahrain
    23
    6
    It's probably the Ballast, I've been having the same issue with flickering Xenon's. Got mine off ebay for cheap, but having to remove the bumper is annoying.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Ballast issue.
    Jan 2013
    3
    So to update: FIXED for awhile now just been away from the forum.
    the fix was I removed the ballast and there was a ton of water that poured out. I looked at the ballast and could see alot of rust on the circuit board. I replaced the ballast used silicone to keep the moisture out and replaced the bulb.
    And just FYI I didn't have to remove the front bumper. I just had to remove the top plastic bolts pull it back and found the third bolt holding it in then after about 2 min of trying to get it out it was free.
    Oct 2012
    975
    Quote Originally Posted by joshkel2004 View Post
    I actually cut both of those brackets off behind the grill saves time for next time around
    CoolATIGuy is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac SRX V8 Northstar AWD w/ 18" wheels
    Jan 2013
    44
    Found this: http://ww2.justanswer.com/uploads/PE...021425_srx.pdf
    Also, what I'm not understanding is why there is a gap between the bottom of the headlight and the top of the bumper (example: http://www.carid.com/images/grilles/...rx-grilles.jpg)
    It's a relatively huge gap, and if you look straight in, you can see it's a clear shot..straight at the ballast!? What in the world..
  12. Remove Advertisements
