Sun Roof Not closing propoerly
Results 1 to 8 of 8
Like Tree3Likes
  • 4 Post By glake89
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Sun Roof Not closing propoerly in Cadillac SRX / XT5 Forums; Hi there I have a SRX 2006 with Ultraview sun Roof ( the big one) When I am driving at ...
    lemmon is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX
    Nov 2010
    79
    Hi there
    When I am driving at 100miles or more I clearly hear the air entering in the vehicle through the sun roof.
    I have checked the sun roof and It seems to be properly closed, however the air is till entering....
    Do you know if there is any way to adjust the sun roof ?
    Do you have any idea how I can solve this issue?
    Many thanks in advance
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: Sun Roof Not closing propoerly
    From the SM-
    Initialization Process
    Important: The sunroof window and sunshade must be in the fully close position before starting this procedure.
    Important: Perform the Teach Module Process immediately after completing the Initialization Process. Failure to begin the Teach Module Process within 3 seconds of completing the Initialization Process will require the entire procedure to be repeated.
    Make sure the engine is idling and the vehicle is in park.
    Press and hold the "Sunroof Open Switch" and the "Sunshade Close Switch" together for 6 seconds.
    Release both buttons.
    Press the "Sunshade Close Switch" until the motor stalls in the close position.
    Press the "Sunroof Close Switch" until the motor stalls in the close position.
    Run the Initialization Process above and within 3 seconds perform step 2 below.
    Press the "Sunroof Close Switch" 3 times and hold the switch down on the third switch press.
    Continue holding the "Sunroof Close Switch" until the sunroof and sunshade have stopped moving.*
    * The sunroof has entered the teach mode at this point and the following operations will be observed:
    • The sunroof and sunshade will move to the full open position.
    • After the sunroof reaches the full open position, the sunroof will begin to close.
    • When the sunroof reaches the half closed position, the front sunshade will close.
    • The Teach Module Process is complete when both panels have stopped moving.
    Been fixin' cars for 74 years
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Lemmon, did you find glake's post helpful? If you are working with a dealership and would like any assistance, please let me know and I'm always happy to follow up with your dealer on your behalf. Feel free to email me anytime at Katie_Lucille@gmexpert.com, and I can investigate further for you.
    Best,
    Katie
    orandaberg Guest
    Hi
    Open your sunroof till you can see the rear screws attaching it to the rail. They may have come loose, you may need to adjust them and make sure you are getting a proper fit in the front seal, you do not need to do the teach if this is all you do, I completely removed mine and did not have to do a teach but it may be different for each car, so use the above from Glake to be sure. You fail to mention where the air is coming from
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    The dealer just replaced a seal for me due to a air leak that was causing a whistling noise.
    GaExt's Avatar
    GaExt is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Sep 2010
    14
    Quote Originally Posted by glake89 View Post
    From the SM-
    • The sunroof and sunshade will move tothe full open position.
    Will this procedure work with the Escalade sunroof as well. Would just try it but not at the house with my truck for the next few days
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,833
    Different systems, but here-
    From the SM-
    Synchronization will be necessary anytime the sunroof motor is removed from the unit. The sunroof module will be synchronized when the controller learns the full vent position.
    To synchronize the sunroof:
    Turn ON the ignition, with the engine OFF.
    Using the close/tilt up portion of the sunroof switch, operate the sunroof glass until it reaches the full vent position. This may take 20 to 30 seconds.
    Continue to hold the switch in the close/tilt up position for an additional 20 seconds when the glass will make a slight movement indicating the module has been synchronized.
    Verify that the system operates normally.
    Once the sunroof glass reaches the full vent position, the actual position is stored in the memory of the sunroof module. The module will retain this memory even after power is removed and restored.
    That should do it.
    munich44's Avatar
    munich44 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 2005 Escalade
    Jul 2010
    Maryland
    60
    Thanks that worked for me
  11. Remove Advertisements
