Motor Mount change difficulty - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Motor Mount change difficulty in Cadillac SRX / XT5 Forums; Just about every car repair I've done, I thought I was over my head. They all worked out fine. You'll ...
  1. #16
    johns12 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8
    Nov 2010
    147
    Re: Motor Mount change difficulty
    Just about every car repair I've done, I thought I was over my head. They all worked out fine. You'll be ok.
  2. #17
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Quote Originally Posted by repnatl View Post
    Soaking them should work then put them back on with some anti seize.
    The thing about anti-seize is it will allow you to over tighten and break them, if you use anti seize do not use factory torque settings.
  3. #18
    subzero32 is offline Cadillac Owners Fanatic
    Oct 2012
    Valdosta GA
    35
    108
    Quote Originally Posted by johns12 View Post
    Any time I do a new repair I have never done I always get a llittle hesitant for some reason. I've got skilled friends to help me out if I get stuck anyway.
  5. #19
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Haven't had any issues yet with anti seize on exhaust bolts just makes it easier to go on and off as long as they are on tight and prevents rust. Just a personal preference.
  6. #20
    Sep 2007
    2,621
    Agreed good product but an inexperienced person with tighten until it snaps.
    Like some headbolts, the torque is different for oiled threads and dry threads.
    I have a friend at a shop that was working on an explorer that broke a manifold stud off, at the end of the day it was cheaper and easier to swap engines, and it is an exhaust shop in business for many years. The customer did not want them to fix the stud so they took it to another shop that messed it up and drilled the head off center then it came back, at that point they could not fix it and out came the engine.
    If you get into trouble ask for help before you make it worse not after lol
  7. #21
    mfleming is offline Cadillac Owners Member
    Automobile(s): 2005 SRX V8 4.6L RWD
    Jan 2013
    Florida
    3
    I searched around and did not find a post from anyone who actually changed the motor mount on a V8 SRX so thought I would add this.
    Just changed the left (driver's side) motor mount on my rear wheel drive 2005 V8 in my driveway using some ramps. I was back in the house and showered up in under 2 hours.
    No need to remove the exhaust manifold I only needed to bend the heat shield up a little to get to the top nut and used a 13/16 box wrench to take it off. I used a 13/16 deepwell socket for the bottom and removed the bottom nut on the right side mount (not sure if this was needed). BTW it's possible the correct size is 21mm.
    I used a hydraulic bottle jack with a 2 by 4 under the oil pan to lift the engine with it off centered towards the driver's side. I leaned the mount forward and lifted up and out to remove and replacement is reversed. I was quoted over $1100 for the job and I got the part for $120 so well worth doing myself.
  8. #22
    Rippin is offline Cadillac Owners Member
    Automobile(s): 2006 SRX V8
    Jun 2013
    1
    I am searching for aftermarket mounts for the 4.6L SRX. Were the left and right mounts the same? Pics would be saweet.
  9. #23
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    Quote Originally Posted by Rippin
    I remember mine being 2 different part numbers
  10. #24
    Jan 2013
    Florida
    3
    I only replaced the drivers side #25971086 but each side has its own part number. I bought it from gmpartsgiant.com but you can just do a search using the part number once you have verified it is the correct one for your vehicle. Sorry I didn't take any pictures.
  11. Remove Advertisements
