Bad Gas Cap? - Page 6
Page 6 of 6 FirstFirst 123456
Results 76 to 86 of 86
Like Tree2Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Bad Gas Cap? in Cadillac SRX / XT5 Forums; Well, I went out this morning, and my order of operation was: 1) tap on sensor/tps area, try to start. ...
  1. #76
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: Bad Gas Cap?
    1) tap on sensor/tps area, try to start. runs like crap.
    2) put dielectric grease on contacts, starts and runs, but like crap.
    3) pull hose off and flip the TB flap. runs like a charm.
    so I think what happens is, over the course of 2ish weeks, the sensor gets 'out of calibration' and by flipping it you zero it out?
  2. #77
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: Bad Gas Cap?
    Well after doing a little 90ish mile trip each way for a funeral, it didn't take long for me to get lights and for it to start running rough, so I pulled over and did the whole 'flip the flipper' and it's running fine again.
    Were all these TBs built overseas or for the lowest bidder or something? I see quite a few people complaining about them.
  3. #78
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: Bad Gas Cap?
    So it's been a while since I've had any issues (and I still haven't since my last post) but it got me to wondering. Is it a heat thing? It's been cold here in michigan and I haven't had any issues, and I'm wondering if the TBs are really sensitive to heat. It's going to be warming up a bit here in MI for the next few days (40s/50s) so I guess I'll find out if that's an issue.
  5. #79
    sljasko is offline Cadillac Owners Member
    Automobile(s): SRX 2006
    Jan 2013
    56
    4
    Re: Bad Gas Cap?
    I'm having the gas cap on my 2006 SRX replaced today. I have had those same issues and my "check engine" light is on (again).
  6. #80
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: Bad Gas Cap?
    Just read thru this thread and see what I've done and see if that fixes anything. Try the 'throttle body flip' if you're able to and I'd be curious if that helps. and I hope you have or know someone with a code reader
    Although I probably should say those issues could be other things, and if you get your codes read let us know here what they are. I changed my gas cap out a long time ago but that wasn't the issue, but hey, new gas cap!
  7. #81
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: Bad Gas Cap?
    So..after all this and changing the TB and still getting the same issues, I went thru and tightened my intake bolts and haven't had an issue since. *sigh*.
    Sad part is the dealership not even trying anything.
  8. #82
    Whiplash_89's Avatar
    Whiplash_89 is offline Cadillac Owners Fanatic
    Automobile(s): 04 SRX V8 AWD, 04 NSRT4
    Nov 2012
    Windsor, ON
    223
    Re: Bad Gas Cap?
    That sucks, but at least you did fix the issue finally.
  9. #83
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: Bad Gas Cap?
    Well I also spoke too soon. the very next day after posting this (my car must be able to read the internet) it had the same issues. Unplugged the throttle body plug, plugged it back in and it was good to go. So I'll replace that pigtail here in a day or two.
  10. #84
    Aug 2012
    Kalamazoo, MI
    48
    335
    Re: Bad Gas Cap?
    You know I feel bad I never resolved this thread. I got a new pigtail and swapped out the old one, found a broken wire in the casing on one of them and I imagine what happened was intermittent contact was having it run 'fine' and when I would jostle stuff around to 'flip the flap' it was 'fixing' it for a bit. After I changed it I never had a problem with it again until the wife decided to do some extracurricular body work to the car.
    So I wanted to thank everyone for putting up with my very strange detective work on this issue. You guys helped a ton.
  11. #85
    vcrvi is offline Cadillac Owners Member
    Automobile(s): 2004 srx
    Dec 2014
    West Michigan
    3
    Re: Bad Gas Cap?
    Thank you so much for the interesting read on yet another gloomy Michigan day. We have a 2004 SRX that showed similar problems just recently. Went like this : 1- New throttle body, lasted two weeks more codes
    2- Took to dealer number 8 coil pack bad they replaced, one week latter more codes
    3- Took to dealer, told plugs probably fouled because of coil
    4- Wife drove home, next day I start replacing plugs notice odd number engine bank has new coil packs I replace even side .
    5- Been four weeks crossing fingers, if happens again I going for that pigtail. Some times you just shake your head and move on.
  12. #86
    Xocticz's Avatar
    Xocticz is offline Cadillac Owners Member
    Automobile(s): SRX
    Feb 2015
    CHICAGO
    5
    Re: Bad Gas Cap?
    Same issue with my 05 SRX. The "Gas Cap" simply means check your fuel tank. Replace either your sensors or replace fuel tank pump. The diagnostic would state that
    there's air in the lines, but how could that be. I changed all sensor and checked pump. Now, error messages are off.
  13. Remove Advertisements
