No Lumbar, can be a easy fix! - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 33
Like Tree1Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, No Lumbar, can be a easy fix! in Cadillac SRX / XT5 Forums; Are you good with a test lamp or voltmeter, you can start with the switch and work back...
  1. #16
    orandaberg Guest
    Re: No Lumbar, can be a easy fix!
  2. #17
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Quote Originally Posted by orandaberg View Post
    No, I am not good with that stuff. Extended warranty to the rescue!!!!! My trusted mechanic is the backup if I ever get into a bind and don't have the time to drop the SRX off at the dealership.
    PJ
  3. #18
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    Hmmm another double post... Sorry about that
  5. #19
    May 2009
    St. Louis, MO
    62
    1,096
    I'm glad to learn of this... My Lumbar has stopped working twice, and both times the dealer replaced something.
    I thought it odd that it broke, considering I only weigh 165, and I never move it except by accident.
    this will be handy to know, once the warenty is gone.
  6. #20
    orandaberg Guest
    What I am thinking is the motor continues to turn till it reaches the end and twists off the head, are there an GM mechanics on this forum that can explain the sync of this system. Is it suppose to have a torque limit so it does not break off the head?
  7. #21
    May 2009
    St. Louis, MO
    62
    1,096
    Hmmm... know any good machinists? have one milled out of aluminum!
  8. #22
    orandaberg Guest
    yes, but the teeth on the motor end would make it expensive to make, I am sure the thread and a dimple indention on the head could be easy for him
  9. #23
    orandaberg Guest
    I did not give up yet, I super glued the head again, this time I drilled a hole before the head to stop before it gets to the head, the pin should take the force,which may be what breaks the head when glued, worth a try since they do not sell the plastic screw
  10. #24
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    I was able to repair mine even easier than that, dropped it off at the dealer, picked it up fixed
    If it breaks again I will give your solution a try.
  11. #25
    orandaberg Guest
    well yeah if I had warranty I would not bother with anything Not saying this will work,will post if it breaks again
  12. #26
    lefaudio is offline Cadillac Owners Member
    Feb 2013
    Re: Lumbar repair, quick and permanent fix using a metal pivot!
    I have come up with a fast, easy, and permanent fix to the broken plastic lumbar positioning screw.
    Parts: 1/4" x 1" bolt, nut and washer.
    Time: after removal, abut 10 min.
    1) Take out the lumbar assembly. (see above posts)
    2) Cut the plastic tie and remove the motor, screw and broken screw end.
    3) Cut off the white plastic nipple that acts as the pivot for the screw. I used a box cutter.
    4) Drill out a 1/4" hole in the same spot as the nipple was.
    5) Insert a 1" x 1/4" bolt to act as a new pivot for the screw. (the screw is hollow, so this is an easy fit)
    6) Tighten up the nut and bolt, then place the washer on the bolt (past the nut) to act as a smoother screw stop.
    7) Wrestle the screw / motor assembly back into the housing
    8) Put on a new tie.
    9) I drilled out two additional holes for a smaller tie near the top of the motor, as I didn't trust the clip, which was distorted after the screw broke.
  13. #27
    Whiplash_89's Avatar
    Whiplash_89 is offline Cadillac Owners Fanatic
    Automobile(s): 04 SRX V8 AWD, 04 NSRT4
    Nov 2012
    Windsor, ON
    223
    AN FYI:
    I can get my hands on all sorts of lumbar motors, screws, plugs, etc. However; I'm not too sure how many of the parts they have now will work with the SRX.
    But if anyone needs anything please take a clear picture of what you need and I will try to get it for you. You just pay shipping.
  14. #28
    orandaberg Guest
    Hi
    So if I understand the treaded part on the new bolt goes insidee the lumbar screw. I assume the bolt is a tight fit in the lumbar screw? whats to prevent the lumbar screw from just spining on the new bolt? I think these motors have a high torque, hence why the breaking of the srew heads, seems like it keeps trying to turn even when it hits the dead spot. By the way mine is still holding up from the mod above, the pin stop. but I could use a couple of lumbar screws if you have them. PM me and I can send my address.
  15. #29
    Nov 2012
    Windsor, ON
    223
    I need a picture of what you're talking about.
    This is what I have as of right now. I was trying to get one of the motors to work with my cutout.
    Sorry for blurry pic, but you get the idea.
  16. #30
    orandaberg Guest
    Hi
    No you do not have it, it was the black lumbar screw, which breaks
    Thanks
  17. Remove Advertisements
