Replacing factory stereo?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Like Tree2Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Replacing factory stereo? in Cadillac SRX / XT5 Forums; I've got a 2004 SRX with the basic 6 disc system. Thinking about replacing this with a new system. Any ...
    Djacobs64 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2006
    39
    I've got a 2004 SRX with the basic 6 disc system. Thinking about replacing this with a new system. Any suggestions? I'm in Aurora, Colorado. If I replace this stereo I'm sure I'll lose the DIC, driver information center.
    Thank you!!!
    orandaberg Guest
    Re: Replacing factory stereo?
    I have a thread on here about replacing a headunit, yes it can be done, on the thread shows what you need for steering controls, and fascia, do not know about 04 but o7 shows DIC on the instrument panel and I did not loose mine with a after market unit.
    dredd2099 is offline Cadillac Owners Member
    Automobile(s): 06 srx
    Oct 2011
    88
    Quote Originally Posted by Djacobs64 View Post
    Thank you!!!
    not really
    Roose likes this.
  5. #4
    irebroff's Avatar
    irebroff is offline Cadillac Owners Member
    Automobile(s): Seville STS 1999
    Nov 2005
    Germany - Bavarian
    86
    Where can you buy such a DIC-Aftermarket-Module?
  6. #5
    Nov 2006
    39
    Can you tell me what type of radio you had installed and who did it for you? I've got a 2004 SRX and your setup looks great. Thanks!!!
  7. #6
    Oct 2011
    88
    check here mr irebroff and mr djacobs
    elbow grease required =)
    at least you just use what you got already
    any aftermarket double din should work and yes, it was my first time doing anything like it
    just followed directions
  8. #7
    harsh24x7 is offline Cadillac Owners Member
    Automobile(s): SRX
    Aug 2015
    30
    1
    I know this is an old thread but maybe someone is around to answer. Just picked up a 2005 SRX and I'm looking at the aftermarket installation. I'm looking to do it like dredd shows but when I popped off the face of the console it has a huge motherboard that runs the entire face of it, what exactly is it for and does it need to be kept (prevents me from creating a hole for the new dub din to fit in).
  9. #8
    BEARBAIT1973 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8 AWD
    Nov 2013
    New Lenox,IL.
    67
    146
    I added an amp in my Equinox and got everything from Crutchield. Great co. to deal with and their customer support is top notch! Beats dealing with the stores such as Best Buy.
  10. #9
    luisjeovanny is offline Cadillac Owners Member
    Automobile(s): SRX 2005
    Dec 2015
    38
    1
    Cadillac SRX 2005 - stereo replace
    Hi I have a Cadillac SRX 2005 and am looking to replace the stereo as I would LOVE to have Bluetooth capabilities, or at least the ability to connect an auxiliary device which I can't... Any advised would be greatly appreciated.
  11. #10
    raustinss is offline Cadillac Owners Fanatic
    Automobile(s): 2007 srx sport v8,1998 sts
    Jul 2015
    38
    120
    Re: Cadillac SRX 2005 - stereo replace
    Any aftermarket stereo shop should be able to direct you in the right direction
  12. #11
    Nov 2013
    New Lenox,IL.
    67
    146
    I would think Crutchfield in Cal. would be able to help you. Their tech and customer service are great.
  13. #12
    Q-Ball is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac SRX 4 Sport V8
    May 2010
    Ontario Canada
    32
    87
    You have a lot of options. Are you looking to do it yourself or have someone else install it?
  14. #13
    Parrisk's Avatar
    Parrisk is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX V-6 AWD
    Apr 2015
    North East PA
    53
    135
    check out iSimple ISGM571 for Apple devices http://www.amazon.com/iSimple-ISGM57...ywords=isgm571
    or ISGM651 for Android devices http://www.amazon.com/iSimple-ISGM65...ywords=isgm571
    around $100 you ADD true streaming Bluetooth, hands free calling, USB and RCA interfaces and 571 APPLE plug, 651 3.5mm jack
    There is not a lot of room in the dash.. I found a spot between the upper and lower glove boxes where the module sits secure and hidden.
    Unplug the radio, plug in the iSimple, then plug the car harness into the iSimple pig tail.. done.. run the mic over and I placed mine on at the lower left of the dash cluster near the tach.
    You lost none of your factory options from Sat radio to OnStar all still function.
  15. #14
    CaseyCX's Avatar
    CaseyCX is offline Cadillac Owners Member
    Automobile(s): 1986 Fleetwood d' Elegance, 2009 SRX
    Mar 2013
    76
    9
    2009 SRX - Factory GPS to InDash aftermarket upgrade
    I would like to upgrade the "antiquated" GPS that is in my SRX. Has anyone replaced the factory unit with an aftermarket?
    Thanks,
  16. #15
    agentsmith80's Avatar
    agentsmith80 is offline Cadillac Owners Member
    Automobile(s): 2005 SRX AWD N*
    Jan 2010
    Cleveland
    36
    90
    Re: 2009 SRX - Factory GPS to InDash aftermarket upgrade
    I installed a tablet in the dash of my 2005. It's on my Verizon account so I use google maps. It's tied into the sound system so I can listen to pandora, watch netflix, google music, etc. I kept my factory Nav unit since it interfaces with all the car's alert messages and fluid changes and all of that. But I also installed a OBDII dongle with bluetooth and have apps on the tablet to interface with the OBDII system to look at more of the car's info. Here's a link to what I did.
    http://www.cadillacforums.com/forums...5-srx-nav.html
  17. Remove Advertisements
