replacement shocks/struts for mag susp
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, replacement shocks/struts for mag susp in Cadillac SRX / XT5 Forums; can you replace magnetic shocks with regular oem shocks/struts, my srx has 147k, and i want to do it cheaply,thanks...
    rblank is offline Cadillac Owners Member
    Automobile(s): srx v8 04
    Jul 2012
    1
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Yes but you'll have a service suspension message and speed limited to 90 mph.
    lemmon is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX
    Nov 2010
    79
    Re: replacement shocks/struts for mag susp
    rdgfx3 Guest
    I need some, too. I'll get some from Amazon for a little over $400 each. Much better than $800 each, but still ridiculously high priced. The ebay shocks are just regular shocks. They're getting around the system by putting a resistor on the connector that plugs into the electronic shocks. I assume that's where the resistor is being wired in. The resistor fools the system into thinking that the shock is present and normal. It probably works. If you knew resistance value of the resistor they use, you could probably save two or three hundred dollars by buying your own resistor. This sounds like a good way to make money on ebay to me. Buy shocks for maybe a hundred bucks or so, buy a few resistors for next to nothing and make $400 bucks on each sale.
    solracmd is offline Cadillac Owners Member
    Automobile(s): 2004 SRX AWD V8
    Apr 2012
    20
    Rdgfx3 I am re-searching this currently as well. I have still not confirmed whether or not my existing rear shocks (which are suspect) are functioning correctly. My one shock has a hole in the bag. Are u tryin to replace front or rear shocks?
    Janisrick is offline Cadillac Owners Member
    Automobile(s): 2006 SRX V-8 AWD
    Sep 2013
    69
    9
    There's a company called Strutmasters which sell a replacement system which includes regular struts and a plug-in resistor which fools the monitoring system. They will not sell the plugin resistors separately. i know this because i asked.They want you to purchase both the shocks and the resistors. I'm pretty sure that they are not using a variable resistor so you could experiment with different impedance values until you found one that worked.
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,224
    Don't pay for a company selling cheap ones with the resistors. Buy the cheap shocks and figure out what resistor to use. Check the Seville forum out. I know that they have the resistor specs in there (~$1). I would guess that they use the same values on mag ride cars. You could always research the resistor spec or take a meter to yours.
    DougC..'s Avatar
    DougC.. is offline Cadillac Owners Member
    Jun 2011
    39
    50
    Im pretty sure my mag shock is functioning, but the bag is torn on my srx too. I think this is for the load leveling, as I no longer hear the loud air compressor kicking on.
  11. Remove Advertisements
