Page 8 of 9 FirstFirst 123456789 LastLast
Results 106 to 120 of 134
Thread: Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps
  1. #106
    Sep 2010
    40
    Re: Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps
    so I had to check my 04 Malibu manual for break in... here's what it says...
    New Vehicle Break-In
    Notice: Your vehicle does not need an elaborate
    “break-in.” But it will perform better in the long run
    if you follow these guidelines:
    • Do not drive at any one speed — fast or
    slow — for the first 500 miles (805 km). Do not
    make full-throttle starts.
    • Avoid making hard stops for the first 200 miles
    (322 km) or so. During this time your new
    brake linings are not yet broken in. Hard stops
    with new linings can mean premature wear
    and earlier replacement. Follow this breaking-in
    guideline every time you get new brake
    linings.
    • Do not tow a trailer during break-in. See Towing
    a Trailer on page 4-40 for more information.
    2007 SRX Manual says...
    break-in. But it will perform better in the long
    run if you follow these guidelines for the
    first 500 miles (805 km):
    • Do not drive at any one constant speed,
    fast or slow.
    • Do not exceed 70 mph (113 km/h).
    • Do not make full-throttle starts; also refrain
    from using the full throttle while driving.
    Avoid downshifting to brake or slow
    the vehicle.
    I highly doubt you could damage anything unless you were towing a 7,000 trailer 85 mph out of the dealership on Day 1. Using dino oil instead of synthetic may cause issues, but I highly doubt it's a break-in issue.
  2. #107
    Odysseyvegas is offline Cadillac Owners Member
    Automobile(s): 2005 CTS
    Aug 2012
    Ontario, Canada
    20
    cfishkin, I've got the rx catchcan, and did the pcv orifice mod. It has definitely helped. I'm still using oil, but about half of what I was going through before. Signifigantly, mileage has improved approx 1.5 mpg, and the engine seems to be running better. The big difference I have noticed is it pulls much better and doesn't downshift near as much for the same acceleration. SC has mentioned that it takes time for the engine to clean itself, and some may never do so dependent on their condition. I did not do this for performance, (I've got an 05 CTS 2.8!) but for better mileage, less oil consumption and better engine life. I recommend this step for anyone considering it. Ymmv.
    (Meant to mention the rx catchcan is a nice bit of kit too. A solid product.)
  3. #108
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    Just an update:
    GM now has changed the orfice size in the PCV barb to app the same size we have been sharing for years on this mod.
    All LFX's now come (2013 april/may build dates) so I guess we did not know what we were doing.......and the new LT1 DI V8 for 2014 now comes with a "much improved oil separation system built into the valve covers to help reduce oil consumption and valve deposits".........LOL!
  4. #109
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Only took them 9 years lol
  5. #110
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    Quote Originally Posted by SC2150 View Post
    Just an update:
    So can we go to the dealer and get one for an LFX motor and it will fit our LY7 motors? Or maybe even the auto parts store.
  6. #111
    Oct 2012
    975
    Quote Originally Posted by rlh6805 View Post
    Auto part stores are def a no go that would be nice if the new ones fit for ours
  7. #112
    BOOM_FIST is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX
    May 2013
    47
    Any update on this "mod"?? Thinking about doing it just to see if it helps at all. Excessive oil consumption going on with my 05 SRX. Just did the spark plugs and found a good bit of oil residue in the intake and intake manifold. HELP!!!!
  8. #113
    Oct 2012
    975
    Quote Originally Posted by BOOM_FIST View Post
    The pcv mod listed cured my oil ingestion in the intake no more in the airbox either. I haven't tried the catch can yet.
  9. #114
    May 2013
    47
    Quote Originally Posted by repnatl View Post
    Thanks for the reply, I'll be doing the PCV mod at the very least then. Anything to help with this issue I'm up for!
  10. #115
    tgar32 is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac cts lux. sport
    Jul 2012
    Quakertown, Pa.
    96
    I cant see the pics in this thread. Does anyone else have the same problem? I am very interested in seeing the process for drilling out this fitting. I installed the RX catch can and from what i have read this is the next logical step.
  11. #116
    desmar's Avatar
    desmar is offline Cadillac Owners Member
    Automobile(s): srx4
    Apr 2012
    ontario,canada
    86
    Pics are not viewable in this thread. I thought these engine don't have the typical pcv , & this is why it never get change just maintain.
    PS my 3.6 v6 srx has 150000+ miles & have no oil consumption, always use Mobil 1 syn oil, I follow the dic recommendations & haven't had any mechanical issues of any types
  12. #117
    Jul 2012
    Quakertown, Pa.
    96
    There is a pcv fitting you can drill out that is a fix for oil consumption with the catch can install. Also i do use Mobil 1 full synthetic and still have issues. Its not the oil but how the engine was broken in, at least thats what i have read from guys on here that have a lot of experience.
  13. #118
    orandaberg Guest
    Quote Originally Posted by tgar32 View Post
    You do not need to drill out if you have the catch can.
  14. #119
    Jul 2012
    Quakertown, Pa.
    96
    Thats what i thought but i wasnt sure. I have read some of the guys on here do both. If thats the case then thats fine with me
  15. #120
    Aug 2012
    Ontario, Canada
    20
    Thumbs up Re: Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps
    Definitely the first mod to do is the drill out of the PCV barb. This is the direct mod which will allow better breathing through your engine's pcv setup. The second mod should be the catch can as it will catch any sludge causing oil, contaminants, undesireables etc, which exist in that engine breathing mist. Both mods support each other, but the first one to do is the no cost one - drill out the pcv barb/fitting.
  • You may not post replies
