Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps - Page 6
Page 6 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 76 to 90 of 134
Like Tree7Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps in Cadillac SRX / XT5 Forums; can anyone provide me the pictures from this post????...
  1. #76
    royr is offline Cadillac Owners Member
    Automobile(s): none
    Dec 2009
    3
    Re: Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps
  2. #77
    Longsnapper52 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS Thunder Gray
    Mar 2010
    Orange County, CA
    38
    1,055
    Is ktr-sb still on these forums....Can anyone dig him up and ask him to relink the pics? This step-by-step is amazing and a valuable resource. It's a shame the pic links went bust.
  3. #78
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    Here is what you need to do:
    Remove the 90* black plastic fitting from the barb on the rear top of the passenger side valve cover:
    Then with a plyers or vice brips, twist it s=both ways to release the bond and pull stright up removing it:
    Then take a 7/74" drill bit and dril both the top hole and the tiny bottom holes. The entire engine is expected to be able to evacuate through these and they ALL clog over time:
    Then clean and push firmly back into place.
    Now you have done 1/2 of whats needed. Then you need a good functionng catchcan installed between this barb and the intake manifold vacuum side (RX for 100% oil trapped, Elite of AMW or Saiku Micchi for 90% plus trapped, Moroso or any other to trap 40-60% of the oil....you want to trap ALL the oil).
    Then your set.
    PJ1520 and PJ1520 like this.
  4. #79
    TimRSRX777 is offline Cadillac Owners Fanatic
    Automobile(s): SRX
    Feb 2013
    126
    Ok.. so my question is this.. most of the posts in this thread are a bit over 6 months old. How many people tried this Fix? Have the people that tried this noticed a change in oil consumption? Has it lasted for 6 or more months? It would be interesting to get some feedback on this as to what kind of results you can expect if you do this? As of now, it seems pretty controversial and I think I maybe saw two posts that described positive results?
  5. #80
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,783
    Excellent question, Tim. Who's man enough to be honest here?
    Been fixin' cars for 74 years
  6. #81
    ktr-sb is offline Cadillac Owners Fanatic
    Automobile(s): 06 SRX 3.6L 2WD
    Mar 2004
    427
    GM has identified several potential sources of excessive oil consumption in LY7s and LLTs installed in STSs, SRXs and CTSs. The modifications to reduce oil vapor passing through the crankcase ventilation system include a revised camshaft cover seal and a revised oil deflector for RWD engines. The modifications to reduce blowby include new rings and a new air filter housing. I note with some dismay that those who should know better mention nothing about these fixes. None of GM's recommendations involve the installation of a catch can.
    The orifice modification did not reduce my oil consumption appreciably. I have had some success with changing oil to Mobil 1 High Mileage 10w30. I imagine I will install the revised cam cover gasket eventually - someone else did a cam cover baffle with a similar strategy, and had good results.
    I suspect that had I followed GM's instructions regarding engine break-in, oil selection, and air filter maintenance, I would have little to no oil consumption, just as 10s of thousands of SRX owners. Failure to properly maintain crankcase ventilation systems that collect water have led to fires and oil leaks. I would rather stick with GM's stock system, which works well when properly maintained. I have an additional 20K miles on my SRX since I personally changed the timing chains, and it still gets over 20 mpg at high highway speeds. I think I will get many more miles on it, stock.
    Lots of misinformation in this board, and I am not interested in replaying old conflicts. All I can say is, pay close attention to the motives of those supplying you with seemingly useful information.
  7. #82
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    My question is I've done the pcv mod and have no physical leaks anywhere even the air box now would a catch can help I use about 2-3 qts per 2500 miles? A little history about my truck well there isn't any history before me lol. Bought it with 69k miles had timing chain failure at 84k and have always used oil. After the chains and SEVERAL DAYS OF CLEANING THE SLUDGE OUT OF THE HEADS AND BLOCK FROM PREVIOUS OWNER consumption is down but not gone. Dealer said the engine is shot at 97k. It runs perfect sucks on gas but no engine issues besides the oil usage. Any suggestions would be great.
  8. #83
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    hey ktr-sb, any chance you'll fix the broken image links?
  9. #84
    Mar 2004
    427
    Probably not, but I dumped them here:
    http://srxturnsignals.shutterfly.com/timingchain/703
    Quote Originally Posted by repnatl View Post
    No.
    http://www.cadillacforums.com/forums...ml#post3020643
  10. #85
    Sep 2007
    Wilmington, NC
    13,986
    Quote Originally Posted by ktr-sb View Post
    ok, thanks ... good enough
  11. #86
    Oct 2012
    975
    That's what I figured I'm pretty much looking at a new engine
  12. #87
    08SRX's Avatar
    08SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    992
    I remain skeptical that this actually reduces oil consumption. With the larger holes the PVC valve will likely react more quickly to crankcase pressure changes and therefore, increase air circulation may occur. Generally, this is helpful in reducing sludge and would increase oil life. However, would the larger holes not also better accommodate the blow by and just be more efficient at feeding it back to combustion? I would really like to see someone post that says their oil use has dropped due to a modified PCV - yet to see one that is definitive.
    There is also a question of legality which should be raised. According to the Federal Clean Air Act, tampering with any emission control device (which this is) is prohibited if it either inhibits or defeats the purpose of the device. Devices may be modified, but would need to be re-certified with the EPA before they will be permitted. In all likelihood, modifying the PVC valve or installing one with a wider orifice would be illegal under the Act.
  13. #88
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    If the oil ingestion is not stopped, then the causes of consumption cannot reverse themselves either.
    The drill mod prevents the oil laden crankcase vapors from back flowing through the OEM cleanside lice intot he air box, but w/out a proper catchcan the cause of the deposits in the ring lands continues and if the rings cannot move freely to properly seat, then the oil consumption issue rarely improves.
    The installation of a properly functioning catchcan stops the oil from ingesting via the intake air charge so it gives the rigns/lands a chance to free up over time (if not to gunked up) and that is whjen oil consumption will improve.
  14. #89
    Oct 2012
    975
    So do you think its possible to save my oil consumption with a catch can?
  15. #90
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    Depends on several factors, one being how well the rings seated intially. If the engine was broken in easy the first 500 miles odds are the rings never seated properly so that cant be fixed w/out removing the pistons and cutting a new crosshatch hone patteren into the cylinder walls. Also, if a DI engine the intake valve coking causes the valve guides to wear and this could be an issue. What it will do is stop further ingestion and give the rings a chance to free up so it should at the very least reduce the consumption over the next few thousand miles of use.
    Order at: www.RevXtreme.com or call direct: 941-721-1826
  16. Remove Advertisements
