Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps - Page 5
Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 134
Like Tree7Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps in Cadillac SRX / XT5 Forums; Originally Posted by 454Casull I still need help with this. I can't get it off. Should I wrap some rubber ...
  1. #61
    454Casull is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS 2.8L 6MT
    Apr 2010
    406
    Re: Free and Fast Oil Consumption Mod/ Fix in Ten Easy Steps
    Quote Originally Posted by 454Casull View Post
    I still need help with this. I can't get it off. Should I wrap some rubber around the vise grip? How much force can I grip the annular ring with before crushing it?
  2. #62
    G32006SRX's Avatar
    G32006SRX is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac SRX V6 AWD
    Aug 2008
    Cleveland, OH
    293
    At least you found yours.
  3. #63
    ktr-sb is offline Cadillac Owners Fanatic
    Automobile(s): 06 SRX 3.6L 2WD
    Mar 2004
    427
    You should be mostly wiggling back and forth, as opposed to gripping and ripping. Just enough pull that each wiggle worms its way out a little bit.
  5. #64
    Apr 2010
    406
    Quote Originally Posted by ktr-sb View Post
    So the locking pliers should be on tight enough that when I'm wiggling, the jaws shouldn't be slipping at all?
  6. #65
    Mar 2004
    427
    That's how tight I had mine.
  7. #66
    mrriverajr is offline Cadillac Owners Member
    Automobile(s): 2005 SRX AWD V6
    Oct 2011
    43
    29
    can u email me pics please. Mrriverajr@hotmail.com
    Some of those shots are with an extra PCV hose I had, just to clarify how the clip works and how the fitting seats on the flange. The sealing is with an o-ring in the fitting, so the flange is a retainer, not a seal.
    I have not tested this mod, but will be monitoring oil consumption. I was up to as much as 1qt per 800 miles. I will, of course, update as I discover more information.
    I have a ton more pix if anyone needs any additional information. I hope you find this useful.
  8. #67
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    oooh, photobuck fail again
    another reason why I use imageshack.us
  9. #68
    Apr 2010
    406
    So everyone who's done this went from significant oil consumption to zero/negligible oil consumption, so far?
  10. #69
    Apr 2010
    406
    Here's to hoping it works.
    BTW, mine didn't have any sealant when it came off; just a tiny dab of red Loctite.
  11. #70
    Apr 2010
    406
    I am disappointed to report that this fix (increasing the diameter of one hole on both sides of the orifice fitting) did not eliminate oil consumption on my engine (LP1). I did my oil change on 7/24, did the mod perhaps a week after that (oil level was still around the midway mark), and I had to put in about 1.5 quarts today to get it back into the high-middle range, from low.
  12. #71
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    There are a few other steps to help with this....let me know if you want the details.
  13. #72
    SRX_Jim is offline Cadillac Owners Member
    Automobile(s): 2004 SRX
    Feb 2011
    23
    I would love to know what can be done to reduce oil consumption. Mine uses a lot of oil so any tips would be appreciated.
  14. #73
    joe0373 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS
    Jul 2012
    Moncton, Canada
    8
    ktr-sb:
    Thank you for the fix!!! I did it last weekend, drove 1500kms and not a drop of oil used. I greatly appreciate the time you put into posting this thread. Imagine if I took my 2004 with 280,000 kms to a mechanic and told him my car was drinking oil...you saved me a bundle
  15. #74
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    I can't see any of the pictures on thia thread for some reason. Anyway you could email them to me?
    repnatl@yahoo.com
    Im curious to try this because not only did I find an incredible amout of sludge in my engine but I was losing close to 1 qt of oil between oil changes just in my intake tube and dripping out of my air box. Thanks
  16. #75
    erdoc48 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX Performance FWD, Platinum Ice
    Dec 2005
    Westampton, NJ
    218
    Hi All,
    I did this mod this AM. I've been following the threads for this very carefully before I attempted this. It's a very easy modification and took me about 1 hour taking my time and including a drive to Advance Auto to get some RTV black. I carefully drilled the 2 holes (one on top and one on bottom of the orifice) and cleaned it with CRC brake cleaner (external cleaning as well as spraying into the orifice hole). Reinstallation was a snap.
    My CTS's oil consumption is currently at ~ 1500 miles per quart. I have realistic expectations as my CTS has 107,000 miles on it and I expect that the valve guides and oil control rings might be somewhat worn (I've used Mobil 1 5-30 EP) since new and switched to the high mileage Mobil 1 since 100,000 miles. If I can reduce oil consumption to say, a quart every 2500-3000 miles, I would be very satisfied with that result.
    Thanks for the help in posting this and your results. I'll post mine once I have a few thousand miles on the car.
  17. Remove Advertisements
