Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
 | Cadillac Forums: Can't open my liftgate after personalization
11-29-04, 05:57 PM
| | Cadillac Owners Member | | | | | Can't open my liftgate after personalization everything worked fine until i tried the personalization. All of a sudden, I can't open my liftgate! There wasn't a step that even mentions the liftgate in the personalization procedure! Any of you had this problem before? All the fancy features made me feel dumb, except the cruise control, which is older than the design in my 98 explorer (on the steering wheel)
Thank you for any tips. |
11-29-04, 07:24 PM
| | Cadillac Owners Enthusiast Cadillac(s): 2007 N* Thunder Gray/Ebony AWD/NAV/MRC '94 MARK VIII | | Join Date: Mar 2004 Location: Illinois Age: 73 | | | Re: Can't open my liftgate after personalization This is from a post I made severaol months ago.
Rear Hatch Door- We started to open the rear hatch one day and the door handle would not budge. In the past it has been very easy to open. When we got home I decided to try it again and found that if I jerked the handle the door would open. Opened and closed it several times and it did not change. Just thought I would try again and discovered that the left tie down D-Ring was up and getting wedged under the door. As soon as I moved the ring down the door latch works fine. Problem may also be caused by sitting in the sun? |
11-29-04, 07:30 PM
| | Cadillac Owners Member | | | | | Re: Can't open my liftgate after personalization Thank you, MorthCyn. I'll check the D-ring when I got home. |
11-30-04, 04:27 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2006 DTS Performance Level 2006 CTS | | | | | Re: Can't open my liftgate after personalization Ditto again on the CC. The GCadillac term for this is smart stick. I call it dip stick. What, you want cruise control on the steering wheel??? Next think you know you will wonder why they had to put an arrow in the gas gauge if it is such a natural thing to put the gas filler on the European side.
And if the features are an overload, be thankfukl you didn't by a European SRX. They have power folding mirrors. |
12-01-04, 05:40 PM
| | Cadillac Owners Member | | | | | Re: Can't open my liftgate after personalization You really hate that CC, mack1a. Despite the liftgate, I still love the car, way better than my loaner Deville, quiet and comfortable seat, the best seat I ever got into. CC on the Deville is on the wheel, but there's no way i'd trade my SRX for it. I agree, it would be much better if our CC is on the wheel, but heck, nothing is perfect in this world. |
12-02-04, 02:13 PM
| | Cadillac Owners Member | | | | | Re: Can't open my liftgate after personalization It's a hardware issue. Dealer quoted bent handle and cable misalignment. Works now. |
12-02-04, 03:32 PM
|  | Super Moderator Cadillac(s): Does it have wheels? Odds are I've driven it. | | Join Date: Nov 2003 Location: TPA / STL Age: 100 | | | Re: Can't open my liftgate after personalization Quote: |
Originally Posted by ywrotk2006 It's a hardware issue. Dealer quoted bent handle and cable misalignment. Works now. | BENT Handle??? What the
__________________ "You ough'ta go and find a brain sale... And find a cheap one, cause you ain't got no trade-in!" - Red Fox |
12-03-04, 02:17 PM
| | Cadillac Owners Member | | | | | Re: Can't open my liftgate after personalization the handle come out more on the left side than the right, that is what 'bent' mean by the dealer. I guess it's caused by the misaligned cable inside. |
12-03-04, 04:34 PM
|  | Cadillac Owners Member | | | | | Re: Can't open my liftgate after personalization When I first got my SRX I found it difficult to open back hatch and many times I thought it was locked when it wasn't. Turns out I need to pull on the right side of the handle, not in the middle or left, and it opens every time easily. It felt like it was supposed to open this way (I did think it was stupid design) but now I'm believing an adjustment by the dealer might solve this. I'm used to it but if it worked properly then my passengers and guest would be able to open the rear hatch without my guidance!! |
12-03-04, 05:30 PM
| | Cadillac Owners Enthusiast Cadillac(s): 2007 N* Thunder Gray/Ebony AWD/NAV/MRC '94 MARK VIII | | Join Date: Mar 2004 Location: Illinois Age: 73 | | | Re: Can't open my liftgate after personalization Quote: |
Originally Posted by Dripps When I first got my SRX I found it difficult to open back hatch and many times I thought it was locked when it wasn't. Turns out I need to pull on the right side of the handle, not in the middle or left, and it opens every time easily. It felt like it was supposed to open this way (I did think it was stupid design) but now I'm believing an adjustment by the dealer might solve this. I'm used to it but if it worked properly then my passengers and guest would be able to open the rear hatch without my guidance!! | Aha! Now I find that the “D” ring I mentioned in an earlier post was no problem at all. No doubt when I moved the “D” ring down I probably pulled on the right side of the handle. Amazing how the mind works or does not work. I do recall later times thinking it was possibly heat causing the problem since the “D” ring was down.
I just, out of curiosity, tried opening the tailgate pulling on the left (driver’s side) and the latch did not want to budge. Pull in the middle and it will open. Pull on the right and it opens much easier. Then other times it does not seem to matter where you pull. Will have the dealer look at the cable adjustment mentioned by ywrotk2006. |
12-03-04, 11:07 PM
| | Cadillac Owners Fanatic | | Join Date: May 2004 Location: Princeton, NJ area | | | Re: Can't open my liftgate after personalization I also have problems with the rear lift gate, particularly when it has been in the sun all day. I haven't tried pulling on the right side versus the center yet; I usually give it a few sharp tugs in a row. Unfortunately the problem isn't reproducible enough to go to the dealer, at least not yet. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
