Dipstick - - V6 vs V8 - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 61
Like Tree3Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Dipstick - - V6 vs V8 in Cadillac SRX / XT5 Forums; This may be the root cause of the timing chain failures. Wouldn't that be a hoot....
  1. #16
    G32006SRX's Avatar
    G32006SRX is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac SRX V6 AWD
    Aug 2008
    Cleveland, OH
    293
  2. #17
    Ranger007 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX 3.6
    Apr 2010
    Oklahoma City
    85
    Re: Dipstick - - V6 vs V8
    "i would think that when you do an oil change and check the oil level with the dipstick right after if it is showing on the cross-hatched area then it's the right length"
    If it were that simple it would be great - but right after I change the oil I know it has the right amount (because I just put six quarts in).
    I would like to know the accuracy of readings when it is 1, 2 or 3 quarts low - and that is the problem I have now with the V8 dipstick in my 3.6
    Bill
  3. #18
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,000
    Quote Originally Posted by Ranger007 View Post
    Bill
    Katie, can you please follow this up and let us know. I too have major difficulty reading the V8 dipstick in my V6.
  5. #19
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Bill
    i don't quite get what you're saying here
    if it's reading right/correct when full after you just poured 6quarts of oil in then why would it not read right/correct when you are low by 1, 2, or 3 quarts?
  6. #20
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,800
    A GM tech told me that any oil level in the cross hatch area is considered full. Below that is 1 qt. low. So, if you were 2 qt. low, no oil would show on dipstick (V-8 style) but would on the longer 6 style.
  7. #21
    08SRX's Avatar
    Jun 2011
    1,000
    Hi Rippy,
    I think I can explain, because I have the same problem with mine. When checking oil (warm or cold), it is almost impossible to get an accurate reading. I usually see the entire cross-hatched area covered in a light coating of oil after wiping the dipstick and reseating it. Quite frankly, I don't believe that is indicative of the level it actually has, because I can check it a few hours later and get a more defined level of oil. In essence, for me to get at least some idea how much oil is in the vehicle I have to make about three readings on different occasions (e.g. cold, after driving and after driving and letting it resettle). My vehicle is a V6 and does not have any oil loss issues, though when readings are this difficult to get - who knows?
  8. #22
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    I never have trouble reading my dipstick, I think 2 issues are getting pushed together. If the dipstick is wrong then ok fine that is an issue but if the dipstick is hard to read that is a different issue.
  9. #23
    Stillrollin is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX AWD V-6
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    Quote Originally Posted by conedoctor View Post
    Which dipstick does your vehicle have? The cable unit in my '08 V6 will show slightly more oil on one side of the indicator marker than the other. This, no matter how long the car has sat after being driven and no matter how many times it is checked without moving the vehicle.
  10. #24
    Sep 2007
    2,621
    I have the cable V8 version in my V8, my 04 V8 also had the same cable style.
    Maybe I am just really awesome but I never have issue checking it, mind you it gets checked in the garage cold.
    I will try checking it hot after a trip on the weekend, I need to change it as well so lots of checking for me.
    But my point was a crappy dipstick and an incorrect dipstick are not the same.
  11. #25
    08SRX's Avatar
    Jun 2011
    1,000
    I have the V8 style in my V6
    The difficulty in reading could be my fault. Below is an excerpt from the manual on how to do it properly: not cold, not hot, but warm and wait for oil to settle several minutes.
    Checking Engine Oil
    It is a good idea to check the engine oil every time you
    get fuel. In order to get an accurate reading, the oil
    must be warm and the vehicle must be on level ground.
    The engine oil dipstick handle is a yellow loop. See
    Engine Compartment Overview on page 5-12 for
    the location of the engine oil dipstick.
    1. Turn off the engine and give the oil several minutes
    to drain back into the oil pan. If you do not do this,
    the oil dipstick might not show the actual level.
    2. Pull out the dipstick and clean it with a paper towel
    or cloth, then push it back in all the way. Remove it
    again, keeping the tip down, and check the level.
    So back to the dipstick issue...
  12. #26
    Sep 2007
    2,621
    I know how to sovle this you guys, I am awesome!
    Instead of replacing your dipstick just replace your engine to match the dipstick you do have, problem solved.
  13. #27
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    As far as I'm aware, there isn't any issues with the timing chain on the Northstar engine nor do most
    consume excessive oil when driven above 3000 rpm's.
    This 3.6 V6 is the first GM engine I have ever owned where heavy oil consumption and stretched timing chain or chains
    is considered not to be a problem by the manufacturer.
    My regret is that I was only forty miles away from a '08 SRX AWD V8 for sale with similar mileage and only a few thousand dollars more than I paid for my present vehicle.
    Had I been aware of the issues with this "award winning" engine which replaced the venerable 3.8liter V6, I would have driven the forty miles.
  14. #28
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    61
    1,096
    Well...
    I got my SRX back from the shop last night - - and the first thing I did was check the dipstick for any part number stampings... There were NONE... NADA... NOTHING anywhere on the stick.
    I too find it a bit difficult to read this type of stick - - it picks up oil off of the side of the tube.
    Katie is researching for us.
    And Rippy found 2 different part numbers - so they did change something sometime.
    The part number I found was 12611594
    The description indicates this part number is used for 2008 to Current SRX's.
    So - did they change the part in 2008, but never updated the book?
    I kept digging... and found another part number: 12595327
    Description states it is for 2004 - 2007...
    So - - perhaps THAT is the flat stick - - - and the other part number is the cable stick.
    It would have been nice if GM has simply put a sticker on the page.
  15. #29
    Sep 2007
    Wilmington, NC
    13,986
    there is definitely a change of part numbers (and apparently styles) between 2007 and 2008
    the 2004-2007 stick did go through two part number changes so possibly one of those part number changes was also a style change
    i would almost bet money on the owner's manual not getting updated correctly as the root cause of this confusion
    it's kind of like one of those things that is so simple and basic that it was either overlooked or it was decided that it wasn't really worth making the change
  16. #30
    Apr 2010
    Oklahoma City
    85
    Rippy said
    "i don't quite get what you're saying here
    if it's reading right/correct when full after you just poured 6quarts of oil in then why would it not read right/correct when you are low by 1, 2, or 3 quarts?"
    conedoctor said
    "I never have trouble reading my dipstick, I think 2 issues are getting pushed together. If the dipstick is wrong then ok fine that is an issue but if the dipstick is hard to read that is a different issue."
    glake89 said
    "A GM tech told me that any oil level in the cross hatch area is considered full. Below that is 1 qt. low. So, if you were 2 qt. low, no oil would show on dipstick (V-8 style) but would on the longer 6 style."
    stillrolling said
    "This 3.6 V6 is the first GM engine I have ever owned where heavy oil consumption and stretched timing chain or chains
    is considered not to be a problem by the manufacturer."
    What I do know is, is that when I have drained the oil (for an oil change) and it was some halfway down the crosshatch area I was not able to measure 6 quarts (or even close) that were drained, it was less than 5 quarts.
    Whether it is easy (or not) to view the oil on the stick (and it is higher on one side than the other) - I have never before had a car I've had to worry about using oil, and now I do and there isn't an accurate way to measure it. How about them apples?
    Bill
  17. Remove Advertisements
