Transfer case fluid change interval & recommendation
Results 1 to 2 of 2
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Transfer case fluid change interval & recommendation in Cadillac SRX / XT5 Forums; After seeing the excellent thread about the t-case chain replacement by JD2004 and 03zx6r: http://www.cadillacforums.com/forums...placement.html I decided to check my ...
    nascarnation is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    68
    452
    I decided to check my owner manual (2004)
    The recommendation is only for "trailer towing" and specifies a fluid change every 50,000 miles (Dexron III).
    Based on how oxidized the oil is in those photos (2 different vehicles), it looks like these run HOT.
    I'd suggest a change every 50,000 miles for everybody, and using synthetic to prevent most of this oxidation.
    Aug 2008
    Indianapolis
    68
    452
    Re: Transfer case fluid change interval & recommendation
    I just changed my t-case oil at 50,000 miles. (04 V6)
    It looked pretty dark but didn't smell too bad.
    Was surprised at how small the oil fill is.
    Not much more than a pint - if you buy a quart of synthetic ATF you'll have plenty left over.
