sooooooo upset! - Page 5
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 82
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, sooooooo upset! in Cadillac SRX / XT5 Forums; just give us a call i have one in stock phone number in my signature under my posts and in ...
  1. #61
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: sooooooo upset!
    just give us a call
    i have one in stock
    phone number in my signature under my posts and in our ad on the right ------------------>
  2. #62
    Vettersandhubby's Avatar
    Vettersandhubby is offline Cadillac Owners Member
    Automobile(s): 2004 cadillac srx v8
    Feb 2012
    43
    50
    Re: sooooooo upset!
    funny I didn't even look at those
  3. #63
    Feb 2012
    43
    50
    Re: sooooooo upset!
    WO-MAN Down Threw out my back last night. All stemmed from doing radiator hose last week. So still gtn plugs changed this week. To all Autozone discontinued the delco plugs #41-986. Had to get from Napa. Will check in later this week. Vetters
  5. #64
    Sep 2007
    Wilmington, NC
    13,986
    Re: sooooooo upset!
    alternate heat & cold ... get well soon
  6. #65
    Feb 2012
    43
    50
    Re: sooooooo upset!
    I know you're gone for the day but Chris thank you Resting up because gotta get Cecelia (after grandmother who passed) back on the road..safely. Talk to you all soon Vetters
  7. #66
    Feb 2012
    43
    50
    Re: sooooooo upset! uh oh!!!
    Was resting my back and who comes through the door...MY DAD!!! Was upset because the car threw my back outta whack. Brought tool box in hand! So got sparkies replaced and he cleaned out the throttle body. Yes that thing stinnnnks after cleaning. As I was told by daddy dearest! Changed four of the spark plugs they got here kind of late so he's going to get the other four tomm morning. Does anyone know if after all changed how do I get the engine light reset> Coils are in very good shape. Fortunately! So right now he and hubby drove around the block instead of smoking neighbors out. Said no more idle. .....since on bed rest at least til Friday will just look at er through the window..(insert tear here) P.S. ONEBAD my dad said you all here are so very sweet..AND THAT THIS FORUM IS AWESOME..EVEN THOUGH MID LIFE CRISIS GOT HIM INTO A ACURA SPORTSCAR..HA! cHRIS will talk at you very soon!Vetters
  8. #67
    Sep 2007
    Wilmington, NC
    13,986
    Re: sooooooo upset!
    the light will go off if you have fixed the problem
  9. #68
    Feb 2012
    43
    50
    Re: sooooooo upset!
    Ok chris daddy doing now..will let u know if light goes off. Thought had to reset something.
  10. #69
    Sep 2007
    Wilmington, NC
    13,986
    Re: sooooooo upset!
    If you have a Tech2 scanner you can manually reset them but it should go off either immediately after the condition is fixed or after 3 ignition cycles with no fault
    good luck
  11. #70
    dctex99 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Lexus RX350, Satin Cashmere Metallic
    Jun 2009
    341
    Re: sooooooo upset!
    To clarify;;everytime you start your SRX the computer checks all these systems and if it sees a problem it either lights a light or flashes a code programmed to come up when a specific problem arises!! So if the problem is fixed, you should NOT see any lights or codes when you start it next. If it seems somehow confused, do as others have and shut it off,,,remove one post of the battery for 30 seconds, re-attach, and THAN start it over;;;basically "rebooting" the computer!!! Good Luck; hope your dad's work does the trick!!!
  12. #71
    Feb 2012
    43
    50
    Re: sooooooo upset!
    Well replaced all plugs but just got that may need to undo battery again. Daddy is gone..part of wva's finest had to go catch bad guys. But will see if mechanic will do because light was off but came back on after hubby drove five minutes to get my back meds. Will pray as usual that this time will be ok. Dad took tools and I dont have to take battery things off. Ugh living the dream!! ;-)
  13. #72
    Sep 2007
    Wilmington, NC
    13,986
    Re: sooooooo upset!
    More than likely a coil on one of the coil packs is bad (and possibly has ruined the plug that it sits on top of)
    the way the misfire codes work is that the light will stay on until the car is started three times without a misfire happening ... so the battery disconnection is a way around that when you don't have a scan tool available to clear the codes (or you can just start the car three or four times and see if the light goes off)
  14. #73
    Feb 2012
    43
    50
    Re: sooooooo upset!
    Chris hubby said dad said may be two...ugh what kind of price am I lookibg at..on top of the 263.00 sensor, the radiator hose, now this. Very upset!!
  15. #74
    Sep 2007
    Wilmington, NC
    13,986
    Re: sooooooo upset!
    well hopefully the two coils are on the same coil pack ... that way you don't have to buy them both
    i'll cross my fingers for you
    and get well soon
  16. #75
    Feb 2012
    43
    50
    Re: sooooooo upset!
    Chris daddy called text him asking which..he said to hubby on the phone that the coil on the left side #1 coil is about to break had to "gingerly" put back in after he changed plugs all the way around. Also said on the right #2 is cracked. Um yeah probobly the problem!! Said didn't want to upset me and make back worse because of all the money this car is costing us. How much are two coils.
  17. Remove Advertisements
