2006 SRX Rear Air Shocks
Results 1 to 10 of 10
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2006 SRX Rear Air Shocks in Cadillac SRX / XT5 Forums; $$$$$$$$ Well, these went bad on me, and I've found that they are VERY expensive to replace. I'd love to ...
    Jeff Wisconsin is offline Cadillac Owners Member
    Automobile(s): 2006 SRX
    Dec 2011
    1
    $$$$$$$$ Well, these went bad on me, and I've found that they are VERY expensive to replace. I'd love to get them replaced with a cheaper pair, not the $800 each price that the garage has quoted me. This hurts.... can anyone offer an alternative that won't break my bank????
    Thanks! Jeff
    nascarnation is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    68
    452
    Re: 2006 SRX Rear Air Shocks
    I'm not familiar with these other than reading the website. Maybe some others can chime in.
    http://www.suncoreindustries.com/CAD...suspension.php
    Also if you want to ditch the electronic suspension, these will fit, but you may have diag codes from the "missing" sensors:
    http://www.amazon.com/ACDelco-540-52...ar=1&carId=001
    lemmon is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX
    Nov 2010
    79
    I have disconnected my front air shocks plugs and I have not received any diag code..
    I did it only for few minutes.....
    I doo not know if the diag codes appears after few miles.....
    I do not know how to disconnect the rear plug for further testings
    joshbetz57 is offline Cadillac Owners Member
    Automobile(s): 04 SRX V8 AWD
    Oct 2010
    36
    6
    gmpartsdirect has replacement shocks for half the cost and you will not have to worry about any codes coming up after installation.
    JB
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    I also sell parts at prices close to what GMPD sells theirs for (except I don't screw you on the shipping charges)
    orandaberg Guest
    Not surprisingly I found a new issue with MY SRX (as some members now want me to say MY SRX and not...God forbid... SRX in general, due to so much negative input I have written on the now MY SRX) on the rear shock, the dotted line represents the opposite side of the rubber cover on the shock, it has a slit in as if someone used a knife to rip it mid section and the bottom of the cover is ripped, the slit looks like it was cut from inside the shock out, in other words the rip is facing out. Plan is to clean the rubber well enough to use some good contact glue and cover the rip with a thin rubber sheet, just to prevent any water or dust from getting in, I assume that's what the rubber cover is for. Will post a pic soon
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Way to revive a 5 month old thread just to complain....
    orandaberg Guest
    Look conehead it was not a complaint, I merely stated what was fact, what I will do for a fix and post a pic, this is not your forum and stop replying to my posts, this is your famous "off topic" so keep it that way. By the way are you not the one who complained because people were opening topics already posted? Stay off my back If you have a issue with me take it up with the moderator
    solracmd is offline Cadillac Owners Member
    Automobile(s): 2004 SRX AWD V8
    Apr 2012
    20
    I know everyone gets mad when repeating old topics but, after multiple searches no luck...... My question, I have a 2004 SRX Northstar, the right rear shock "bag" or is it a "cover" has a small pinky nail size hole in it ..... does that mean the shock is bad? .... or does it just provide coverage protection for the seals.... when starting up you can hear the pump come on (as always) for about 5 seconds and then goes off ... thanks in advance
    Sep 2007
    2,621
    Did you use the "search this forum" option?
    There is a pile of info on this covered every other month with every result.
  13. Remove Advertisements
