Oil chain
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Oil chain in Cadillac SRX / XT5 Forums; I am planning to do my first oil chain by myself and I have a couple of doubts.... 1.- quantity ...
    lemmon is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX
    Nov 2010
    79
    Oil chain
    1.- quantity of oil needed for the change.
    2.- do I need to replace the oil filter every time I do an oil change.... I am planning to do an oil change every 10.000 km/7.000 miles
    Thanks
    Tx_Lee is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Escalade (sold)
    Mar 2010
    Houston, TX
    30
    92
    Yes, you must change the oil filter everytime you change the oil.. For the amount of oil u need, it depends on which engine u have. The 6.0L obviously takes more oil than the 5.3L and I think the 5.3 takes about 5-6 qts if not mistaken...
    Mar 2010
    Houston, TX
    30
    92
    It's recommended you do an oil change every 3 months or 3,000 miles.. But I do every 5,000 until I hit 75,000. After I hit 75,000 I plan on using the more expensive synthetic oil which allows u to go I believe around 10,000 miles..
    sgilbert's Avatar
    sgilbert is offline Cadillac Owners Connoisseur
    Automobile(s): ('04 SRX N* AWD) '11 Lincoln MKT AWD
    Mar 2004
    South Bend, IN
    71
    1,049
    Re: Oil chain
    Hey Tex, this is the SRX forum. No 6.0 or 5.3's here.
    Lemmon, 6 or 8 cyl. ?
    Nov 2010
    79
    Re: Oil chain
    Sorry It´s 6 Cylinders... So I do not know the quantity of oil I will need
    I forgot to mention I am going to use Mobil1 5-30... synthetic
    Do you recommend different change intervals or 10.000 km/7.000 miles are ok
    Thanks
    Thanks
    sgilbert's Avatar
    Mar 2004
    South Bend, IN
    71
    1,049
    Re: Oil chain
    Sorry, I had the V8 N* which held 7 1/2 qts.
    Have you looked at your Owners Manual?
    I would trust the computer algorithm for oil changes, or max of 1 year. That is what Caddy recommends.
    SLCLK500's Avatar
    SLCLK500 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 SRX V6 (& the two MBZ in my ID)
    Feb 2011
    Rowlett, Texas
    61
    164
    Re: Oil chain
    Here's from the manual:
    Engine Oil with Filter
    3.6L V6 - 6.0 qt (5.7 L)
    4.6L V8 - 8.0 qt (7.6 L)
    nascarnation is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    68
    452
    Re: Oil chain
    Yeah 6 quarts on the V6. FWIW I'm using Pennzoil Platinum and changing when the oil life monitor says 20% life remaining. Typically 8000 miles or so.
  11. Remove Advertisements
