Results 1 to 4 of 4
Thread: Can the popping transfer case issue be diagnosed by removing a fuse?
    kebm is offline Cadillac Owners Member
    Automobile(s): none
    Nov 2011
    Question Can the popping transfer case issue be diagnosed by removing a fuse?
    Hi. I am currently shopping for an SRX. I found one I like at a very good price because of a popping sound on hard acceleration from a stop. I plan to fly in to pick it up and drive it home (1,043 miles), then repair the transfer case myself at home. My question is, when I get there to look at the SRX, can I diagnose that it is actually the transfer case chain slipping, by deactivating the awd. Does the SRx have a fuse for the awd or abs that would disable the awd? My theory is that if the awd is deactivated, the popping will not occur. Thanks
    Aug 2011
    57
    94
    Re: Can the popping transfer case issue be diagnosed by removing a fuse?
    Hi
    I think when the TC is popping you wouldn drive that distance
    The AWD, for my opinian, can't be deactivated, because its a permanent AWD. The TC is direct attached.
    If the slipping is very bad you will hear the popping sound even when you touch the troudle
    CU
    Automobile(s): none
    Nov 2011
    Thanks for the reply. The seller says the only time that the popping occurs is upon full throttle acceleration.
  5. #4
    Aug 2011
    57
    94
    Hi kebm
    Look at http://www.cobratransmission.com/ for the replacement chain
    Good luck
    and carefully use the throttle
    CU
  • You may not post replies
