SRX Possible video & Audio AUX - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, SRX Possible video & Audio AUX in Cadillac SRX / XT5 Forums; thats for the cd changer....
  1. #16
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    Re: SRX Possible video & Audio AUX
  2. #17
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,802
    Go to post #3- in upper right of schematic shows video aux in (Pu & Bk). In lower ctr of schematic shows video from tuner to display (shielded Pu & Bk). The numbers, eg.13, 14 are the corresponding positions on the connector faces. I think one or the other of these is what you are looking for.
  3. #18
    lemmon is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX
    Nov 2010
    79
    Quote Originally Posted by glake89 View Post
    Thanks
    This is exactly what I was looking for. I have cut E7 and E8 from main radio connector and now video it's working as well.
    However now I have same problem than everybody: " no video while driving"
    I have tried everything including faumous 1791 code but nothing.... I have seen in main radio connector that E2 correspond to speed signal... I was wondering if cutting that wire while avoid this protection.
    h
    I do not want to watch movies while driving, but I wouuld like to have my iPod content ( album, picture, sound name, etc) on the screen.
    Any idea how to turn this security feature off?
    Thanks in advance
  5. #19
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,802
    Why not remove the radio connector, then remove wire E2 from the connector. Replace the connector and see what happens. If it doesn't work you can put E2 back in and nothing has been cut.
  6. #20
    Nov 2010
    79
    Quote Originally Posted by OffThaHorseCEO View Post
    Maybe you are right.... But I have tested all Cd functions with this connector unplugged and everything works... I have not seen any difference
  7. #21
    Nov 2010
    79
    I have tried already... Wire related to speed signal was F2 and not E2 as I mention in my previous post,
    In any case result is the same .... It does not work....
    I do not know what else can I try...
    Maybe disconecting data wire will work..... I can install a switch in case data wire is used for transferring information between car & radio
    Thanks to everybody for their inconditional help... I hope you can help me once again
  8. #22
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,802
    Somewhere in the literature, service/owner manual, diagnostics, specifications,operations, whatever there must/should be mention of the front entertainment shutting off when driving. That should lead you to a means to defeat that function. Sounds like a good rainy day search project. BTW, since your car has rear entertainment, there should be a remote control which would make using the rear aux in jacks easy to use, no?
  9. #23
    VinceTheFrench's Avatar
    VinceTheFrench is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX V6
    May 2013
    In France near Lyon
    31
    45
    This post is very good. I think, one day, I will try this. (when I succeeded install the firmware in my nav unit ...).
    Thank for this good post.
  10. #24
    wibbsy is offline Cadillac Owners Member
    Apr 2015
    3
    Hey
    I hope someone can assist. I have a 2006 Cadillac SRX with the factory stock radio (see pics)
    https://www.copy.com/s/s68k1PbcAsGee2x2/cad.jpg
    https://www.copy.com/s/h6x0KRPJ2qSRQWmx/cad2.jpg
    What is the simplest (read: cheapest) way to add a 3.5mm AUX in so I can hook up my mobile, tablet etc... I'm not interested in full iphone connectivity or anything like that.
    Thank you
  11. Remove Advertisements
