Rear wiper
Results 1 to 12 of 12
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Rear wiper in Cadillac SRX / XT5 Forums; Can anyone offer a suggestion for a good rear window wiper replacement? I replaced it with a Bosch Excel+ (41913) ...
    Thrill6's Avatar
    Thrill6 is offline Cadillac Owners Fanatic
    Automobile(s): 11 CTS-V Sedan, 07 Corvette Convertible
    Oct 2010
    Columbia, MD
    237
    Rear wiper
    Can anyone offer a suggestion for a good rear window wiper replacement? I replaced it with a Bosch Excel+ (41913) but it doesn't wipe very well.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Re: Rear wiper
    On our 04 anyway it was not the wiper blade at all but the arm pivot point was tight so the arm did not stay in good contact, I would use dielctric (sp?) grease every few months and it solved the issue.
    sgilbert's Avatar
    sgilbert is offline Cadillac Owners Connoisseur
    Automobile(s): ('04 SRX N* AWD) '11 Lincoln MKT AWD
    Mar 2004
    South Bend, IN
    70
    1,049
    Re: Rear wiper
    +1 Totally agree.
  5. #4
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: Rear wiper
    I'll have to try that. Old blade, new blade, not much difference........the rear wiper on mine doesn't do the greatest job. I had chalked that up to the exhaust and other grimy filth the rear hatch window is sunjected to.
    Thanks.
    PJ
  6. #5
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    61
    1,096
    Re: Rear wiper
    My rear wiper is an RainEx... I put a stronger spring in the arm. wipes fine.
  7. #6
    Thrill6's Avatar
    Oct 2010
    Columbia, MD
    237
    Re: Rear wiper
    I checked the rear wiper and there wasn't any binding or stiffness in the hinge and flexed very easily. I'm gonna try a new wiper because none of the swept area of the wiper is clear and the "smearing" is pretty even.
    On another note, does everyone else's washer fluid just spray into a tight stream on the back window? It would think that it should spray and spread over a much larger area like the front does.
  8. #7
    May 2009
    St. Louis, MO
    61
    1,096
    Re: Rear wiper
    Mine sprays in a single stream up the middle.
  9. #8
    wrupert is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX N* AWD, 2009 SRX N* AWD, 1986 Buick Grand National
    Aug 2011
    Michigan
    122
    Re: Rear wiper
    Does anyone have any more suggestions on this subject, Both the 04 and 09 do the same thing with the wiper. Cone and Professor, stronger spring and grease, I will try the grease and Professor, where did you get the spring to replace?
  10. #9
    cfishkin is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    148
    Re: Rear wiper
    Quote Originally Posted by conedoctor View Post
    LOL, I had to do the exact same thing for the exact same problem.
  11. #10
    CADMAN2's Avatar
    CADMAN2 is offline Cadillac Owners Member
    Automobile(s): SRX4
    Oct 2012
    34
    Had the same problem. Went to SAMs Club to get a winter wiper 13". Tech looked at it and was really stiff to move he used some dielectric grease freed right up making good contact. Now even though I didn't need it now I bought the new blade for the great service he didn't have to provide. New blade would be the same if he hadn't freed it up. Not the first one he's seen I suppose.
  12. #11
    08SRX's Avatar
    08SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    992
    Re: Rear wiper
    Quote Originally Posted by Professor Wizard View Post
    Mine also sprays a single stream up the middle. What's worse is that it only reaches about 60% of where the wiper moves. It is not adequate. Has anyone experimented with a different (smaller) nozzle that can spray farther?
  13. #12
    CADMAN2's Avatar
    Automobile(s): SRX4
    Oct 2012
    34
    Forgot to mention mine sprays a single stream up th middle , but it is a strong spray that cleans very well. No complaints there.
  14. Remove Advertisements
