Results 1 to 8 of 8
Thread: A/C consensation drain, water in floor!!!
    bahner1 is offline Cadillac Owners Member
    Automobile(s): 2004 SRX 3.6
    Dec 2009
    Ohio
    49
    19
    Does anyone know where the drain is for the evaporator box. apparently mine is plugged and is dripping water into the passenger floorboard instead of outside the vehicle!!!
    Dec 2009
    Ohio
    49
    19
    Re: A/C consensation drain, water in floor!!!
    Found the drain tube right behind the a/c control, driver's side. It drains to thru the tunnel, exiting above the transmission.
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    On trips to Florida, mine drips COLD water onto my accelerator foot... Come to find out, condensation builds up on the outside of the venting and eventually drips down on my foot. They ended up not fixing that after the original fix ended up leading to another big fiasco with the heater. (Read my What's Wrong With" thread).
    After their fix made problems for me later, I fixed it myself by making a shield out of an old piece of thin black plastic that catches anything that falls out of the dash before it hits my foot!
  5. #4
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    PROF = McGyver (1985-1992).
    PJ
  6. #5
    drjothen's Avatar
    drjothen is offline Cadillac Owners Member
    Automobile(s): 2005 SRX AWD & 2005 CTS
    May 2009
    Damascus, OR
    57
    22
    Quote Originally Posted by bahner1 View Post
    How did you get to it? We are having the same issue and I would like to correct.
    Thanks in advance,
    DRJ
  7. #6
    UNKUT's Avatar
    UNKUT is offline Cadillac Owners Fanatic
    Automobile(s): 2000 DTS / 2005 STS
    May 2009
    Ohio
    36
    380
    Quote Originally Posted by drjothen View Post
    Thanks in advance,
    DRJ
    I'd like to know as well... I've been searching for a pic so that I know what I'm looking for but theres nothing nowhere.
  8. #7
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,921
    DRJ & UNKUT, remove the console, the drain tube is on the driver side, draining out the cabin over the tranny.
  9. #8
    Bluzman is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Aug 2013
    71
    I had the same problem on my 2000 Deville, passenger side floor and mat were soaked. The drain hose underneath the passenger side by the firewall was plugged. Took it in, found the hose, squeezed it and about 1 quart of water poured out. Problem solved. Happens every 3 or 4 years.
  • You may not post replies
