05 SRX oil change gone bad
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 05 SRX oil change gone bad in Cadillac SRX / XT5 Forums; My neighbor tried to take the top off of the oil filter housing during an oil change and things didn't ...
    MachoMan is offline Cadillac Owners Member
    Automobile(s): 98 Deville
    Apr 2011
    Badger Land
    6
    My neighbor tried to take the top off of the oil filter housing during an oil change and things didn't go as planned.
    Suggestions on what parts need to be replaced now would be appreciated.
    Thanks
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    787
    Re: 05 SRX oil change gone bad
    One source shows the cap as GM part number 12583470. Retails for around $50. Perhaps Chris @ Rippy can verify the p/n and availability. Rippy Cadillac is listed on one of the banners on the right side. I think Chris is in the parts department and could probably expedite getting you one.
    There's been reports on this forum of others having a hard time getting this cap off. However you're the first I've seen to report actually breaking one! But things happen. When replaced retorque to 18 ft-lbs. Should be obvious but check in the cavity to make sure all metal fragments are removed.....
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,783
    Use a 6 point socket, 1 1/4" I think. Problem solved.
  5. #4
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the v6 3.0L in the catera and the saturns would often have this problem (oil filter cap breaking)
    i'm not sure why since nobody in our shop has ever had it happen to them but we've sold a ton to lube shops in town (and ones out of town too)
    the part number in this instance is indeed #12583470 $49.95 (list price) - $36 (forum discount price)
    i can get them pretty quickly (one or two days) although i would assume you'll want it as quickly as possible and ordering it locally will probably be your best bet at getting it quickly
  6. #5
    Thrill6's Avatar
    Thrill6 is offline Cadillac Owners Fanatic
    Automobile(s): 11 CTS-V Sedan, 07 Corvette Convertible
    Oct 2010
    Columbia, MD
    237
    The blame should be on who ever changed your oil the last time. The correct procedure is to put a coating of oil on the threads of the cap before replacing it so the next time the cap will come off.
  7. #6
    Apr 2011
    Badger Land
    6
    I was able to get the cap off after work today. It was a job and a half, but I was able to save him a few dollars.
  8. #7
    jcobz28 is offline Cadillac Owners Member
    Nov 2006
    82
    Wow, that is nuts. Looks like someone used an impact gun set at 150 ft-lb to crank that sucker down. At least it is a relatively easy part to access and replace. It could have been worse and been a stripped drain plug!
  9. #8
    dctex99 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Lexus RX350, Satin Cashmere Metallic
    Jun 2009
    341
    Just one more reason why I always change my own....I swear oil changers are all idiots that only feel they can prove their manhood by overtightening EVERYTHING!!
  10. #9
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Some ppl go by the tightening and direction the arrow shows on the cap and this is the result.
  11. Remove Advertisements
