Results 1 to 10 of 10
Thread: '06 SRX cranks, but won't start. Help me diagnose?
    e2mtt is offline Cadillac Owners Member
    Automobile(s): 2006 SRX, (sold - 2000 DHS)
    Jun 2008
    32
    06' SRX with about 90,000 miles. Tried to start it today, it just cranks, doesn't fire at all.
    It worked fine yesterday, all the way home & parked in my garage. Today, nothing. No check engine light, no error codes of any kind. Plenty of gas. Oil was low (as always, uses it like crazy) but still on the dipstick, I filled it up. Battery is nearly new & cranks strong. I put some starting fluid in the intake, it still didn't fire.
    I'm thinking spark/ignition - what should I check first? Any other suggestions? Thanks.
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: '06 SRX cranks, but won't start. Help me diagnose?
    I'd check for spark first. Then would suspect the fuel pressure regulator gone bad, or a failed fuel pump @ 90,000 miles......check for fule pressure. Both very fixable.
    PJ
    John Walker is offline Cadillac Owners Member
    Automobile(s): '92,'93,'94&'95 Devilles, '03 & '12 CTSs
    Jan 2005
    41
    I have the ~same problem. So, the question for me is basic diagnostics on the modern car.
    (1) checking for fuel is simple - now, measure fuel pressure using the injector rail port..
    (2) checking for compression is pulling plugs, which is no longer so easy.
    (3) checking for a spark. My cts '03 has coils at the plug so not as simple as using a timing light, and not that easy to pull. So, TBD
    (4) Checking value timing. The belt has to be working and all the sensors. So, what's the easiest way to know that the timing belt is still functioning. A day not that long ago, one could look under their oil cap to watch the valves. I can handle doing test leads to sensors if needed.
    Maybe the answer is simple - Go get xxxxxx scanner. It lets you see incoming data.
    Or, you should have a xxxxxxxx because it lets you set parameters like a tech 2.
    Thanks for the help,
    John
  5. #4
    Jun 2008
    32
    Follow-up reply - it fixed itself & I have no idea how. We towed it up to my very good local mechanic. It still wouldn't start there. They put a pressure sensor on the fuel line, it was fine. They checked the battery. Then we opened up the air intake, sprayed a bunch of starting fluid in, and cranked for a while. Eventually it started & has now been running fine ever since.
    One guy was convinced that it was just flooded all along. Other than that, we were all stumped. I'm just happy its running good now.
  6. #5
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    I had cranking problems when my cats were bad. Since bad cats are a common problem for the SRX you might want to check that. It should be a waranty matter.
  7. #6
    CaddyinKC's Avatar
    CaddyinKC is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac SRX AWD V6 Blue Chip Luxury and Performance Package
    Nov 2006
    Overland Park, KS
    159
    Quote Originally Posted by e2mtt View Post
    I had the same exact issue with my 04 v6 and the mechanic suspects the same thing....flooded.
  8. #7
    Feb 2010
    New England
    2,005
    e2mtt........Don't give it any gas when starting, let it start itself by just turning the key. Pressing on the accelerator even slightly when starting could very well have flooded it.
    PJ
  9. #8
    SRT ACE's Avatar
    SRT ACE is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    82
    I had this problem once before. It happened after I started the car, moved it five feet, shut it down, and then shortly thereafter tried to start it again. If I remember correctly, I read that the engine sprays extra fuel into the cylinders upon shut down - basically the short on/off cycle resulted in a flooded condition as previously mentioned.
    ACE
  10. #9
    mstonya610 is offline Cadillac Owners Member
    Jun 2012
    37
    27
    I am not sure what "cats" are can you please explain?
  11. #10
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    catalytic converters...their purpose to finish burning any unburned hydrocarbon (fuel) present in the exhaust.
    Bill
  • You may not post replies
