Hatch won't open
Results 1 to 13 of 13
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Hatch won't open in Cadillac SRX / XT5 Forums; The back hatch in my 2004 SRX is locked tight. You can hear the unlatching mechanism click, and the other ...
    Old_Soldier's Avatar
    Old_Soldier is offline Cadillac Owners Member
    Automobile(s): 2004 SRX
    Feb 2006
    Indianapolis, IN
    25
    Hatch won't open
    You can hear the unlatching mechanism click, and the other doors lock and unlock but pulling on the lever in the back just gives you shoulder problems.
    My dealer says they have not heard/seen this problem.
    Any ideas on how to DIY to get it open - without damage?
    skwerlabusr is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac SRX
    Apr 2010
    U.S.A.
    24
    51
    Re: Hatch won't open
    The same thing happened to me and I had no hatch for months! I got mine open by climbing into the trunk through the second row seats. Pulling a little bit off the trim cover and reaching in and pushing the latch over to the left. There is a little black button that also slides up and down (towards the sky and ground). One position is locked and one is unlocked just try each one. You will know when it opens up. After it opens up go to the back of the car, completely take off the panel, and double check the cables (kind of like on a bicycle brake). Make sure you don't close it without making sure the handle and latching works! These pictures should help. I can explain what's going on if you need me to.
    compfan03 is offline Cadillac Owners Fanatic
    Mar 2004
    131
    I had the same problem. In my case, my rear window glass was crashed a year ago. The rear window was replace, but somehow one little piece of glass remained in the back and finally worked its way into the lock. The dealer had to take the entire tailgate apart and order a new piece. It took about a week but is now working just fine.
    Q-Ball is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac SRX 4 Sport V8
    May 2010
    Ontario Canada
    32
    87
    I was told mine was some electrical module. First thing I noticed was wrong was the way the hatch closed. It looked as if it would fall off track a few time as it was closing on its own with the power lift gate.
    Took it to the dealer and said they ordered a new module. Said new module was defective. Got the SRX back and they ordered another one. It's been at the dealership for over a week now. They said the 2nd one was defective too. So they ordered the 3rd one. I havent heard anything since Monday.
    I dont know how they got my hatch open, probably the same way as mentioned above. But they had to check all my wiring and now have GM Engineers working on it. Basically they have to do what the engineers say and report back. Than the engineers tells thems what to do next.
    I was told in some cases, it took 4 modules to respond to the system. In the mean time, I've been driving their loaner of a 2010 CTS. It's alright, but I prefer my SRX. I'm still waiting to get it back to put my weather techs in, bug deflector, and mud flaps.
    Feb 2006
    Indianapolis, IN
    25
    Many thanks to skwerlabusr for his detailed diagrams on the fix for this problem. He went the full measure.
    Unfortunately, I had to go to the dealer and it cost approx $280 to have them fix it.
    The cable had come loose and did not have enough tension to release the latch.
    Infrared in Idaho's Avatar
    Infrared in Idaho is offline Cadillac Owners Member
    Automobile(s): 04 SRX V6 AWD
    Nov 2006
    The land of Freedom
    94
    Thank you SKWERLABUSR. You are a life saver! Saved me from going to the dealer, who probably wouldn't have know how to fix my hatch in the first place. Many thanks!!!
    Apr 2010
    U.S.A.
    24
    51
    No problem! I'm glad it helped someone!
    Quote Originally Posted by Infrared in Idaho View Post
    Bigg Jim is offline Cadillac Owners Member
    Automobile(s): 2005 SRX
    Jan 2011
    52
    1
    I just had the same issues this weekend while on a family trip and could not load or unload using the lift gate all 5 days UGH !!! I have a 2005 SRX, with out the power lift function. Looks like from reading the history on these threads, it could be a cable, module, or fuse Issue. I assume the fuse is the best place for a DIYer to start, but then what crawl through, pull off some trim and try to manually open so i can check the cable inside the lift gate ? How come this stuff all happens just as the warrantee runs out !!
    flopyle is offline Cadillac Owners Member
    Oct 2013
    Texas
    1
    Hello
    I just had this problem, when we were changing the license plate bulbs.... We removed the entire panel to lifthgate etc. Replaced bulbs, put panel back on, closed the liftgate without checking it worked, closed and now, will not open. Have hit the key FOB lock, unlock and definitely is working, apparently we either disconnected something or pinched a cable. Is there some hidden screw somewhere that will allow manual unlock.. Called the dealer, they want $200.00 to look at it, on a budget this DIY everything we can....
    Do you have a diagram or suggestions..... this has not been my year for life, cars, people what a mess..
    Any suggestions, guidance, jokes would be GREATLY appreciated at this point..
    Thank you
    FP
    Feb 2006
    Indianapolis, IN
    25
    It is a shame that the photos/diagrams are no longer available.
    1olddukester is offline Cadillac Owners Member
    Automobile(s): 2006 SRX
    Dec 2013
    60
    hi, could you share this procedure with me as I think im having the same issues....Thanks
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,708
    The factory service manual rear lift gate door theory of operation and disassembly instructions are here for $5 a day; you can cut and paste the procedures into a Word document for later retrieval:https://www.repairprocedures.com/index.php
    CC
    Pinhauler is offline Cadillac Owners Fanatic
    Automobile(s): 06 v6 SRX
    Sep 2009
    Troy / Mi.
    64
    359
    ccclarke - Who in the world would pay $5.00 a day for a manual ? That's $150. a month !
  16. Remove Advertisements
