oil filter cap overtightened
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, oil filter cap overtightened in Cadillac SRX / XT5 Forums; hi , I was trying to change the motor oil and filter and I couldnt open the oil filter cap ...
    heccercal's Avatar
    heccercal is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX 2006
    Jan 2007
    59
    12
    hi , I was trying to change the motor oil and filter and I couldnt open the oil filter cap , my car is 2006 srx and the oil filter housing is aluminum and I am afraid to damage the part (oil filter cap), does anyone know how to loosen it, and what direction does it open, the cap has stamped on top "25 N" and an arrow showing clockwise direction
    thanks for any pointers you can help me with
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    792
    Re: oil filter cap overtightened
    The oil filter housing is conventional right-hand thread, meaning ccw to loosen.
    I believe the nut is 24mm but a 15/16 socket fits snugly. Don't use a cresant wrench.
    The 25N is actually 25N-m and I believe is the recommended torque when reinstalling the filter housing. 25 newton-meters is approx 18 lb-ft torque.
    I use a socket with an extension. To loosen often takes an initial shock by firmly hitting the handle
    heccercal's Avatar
    Jan 2007
    59
    12
    thanks for the help, Since its my first time changing the oil after dealer services, and having the cap overtightened at the dealerchip , I just to make sure I was unscrewing it in the right direction, being an aluminum part and all, anyways going to give it a try, thanks again
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    I suspect you already drained the motor oil/changed the filter and your SRX must be refilled, short of having it flatbedded back to the dealer who seemingly overtorqued the filler cap somehow or misthreaded it during the last oil change. The likely culprit is the last person to add a quart or change the oil. The filler cap could have been overtorqued and'or misthreaded by the last person to put motor oil in there.
    Can you determine who that is and let them resolve it? If you touch it the problem and potential stripped threads becomes yours. Risk versus opportunity or practicality. Your choice.
    Jan 2007
    792
    PJ I think he's talking about the oil filter housing. Even when properly torqued I've found it takes a jolt to initially loosen.
    Feb 2010
    New England
    2,005
    Sorry.....thought he said oil "filler" cap, not filter.
    We old guys used to run into this overtightened oil filter problem all the time. The rubber filter sealing ring was supposed to be lubricated with a couple of drops of fresh motor oil using one's index finger, then be snugged BY HAND, then tightened just a tad more with an oil filter noose-type slip wrench.
    Mechanics would overtighten the filters so badly the only way to get them off yourself was to drive a very long screwdriver clean through the filter housing and using brute force and both arms to break them loose. Some mechanics had oil filter wrenches with a very long handle and could get the leverage with those.
    In this situation I can't recall how much room there is to operate in there....maybe not a practical solution.
    I might be inclined to tell the guy who changed the filter last to make a house call and take off what he overtightened on beyond the 18 pounds.....and I am just the disgruntled type to do so. Or alternatively suggest he flatbed the SRX back to his place to do it since he was the culprit, last guy to have touched it. His choice. Then stripping the aluminum threading for the filter would be HIS worry.
    Sometimes the compliance of the offending mechanic comes at about 7:45AM on a busy Monday morning with a bunch of (his) other customers standing around taking in your story and the dilemma he has placed you in.
    nascarnation is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    68
    433
    My experience is that you can lube the threads and seal ring, torque it to 18 lb ft, and after 7500 miles or so it still takes two men and a boy to get it loose.
    I think it's because there is a huge amount of thread area in engagement compared to a bolt or fitting.
    For those who aren't familiar, if something goes really bad (ie buggered up threads on the female part) that's not the engine block, it's a bolt on adapter that looks like it can be replaced.
    heccercal's Avatar
    Jan 2007
    59
    12
    thanks for the input, after several thugs and no go, took it back to the dealership let them make the oil change, (they must have impact wrench or something) anyways all is good again
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    People think the filter cap holds the engine together. You only need tighten it enough to keep it from coming loose.
    That big o ring on the cap keeps it from leaking.
    (this is a metal can with an insert for those following along)
    Every one I get is too tight.
    I actually know of someone who pulled and it broke loose, he hit his elbow on the fender sheet metal and severed the nerve conduit in his elbow and now has permanent nerve damage.
    Yikes!
    Be careful!
    heccercal's Avatar
    Jan 2007
    59
    12
    mechanic at the dealer told me to untighten it when oil is hot
    Aug 2008
    Indianapolis
    68
    433
    Shouldn't help.
    Both mating threads are aluminum so no differential expansion there.
    o-ring expands faster than aluminum so will be tighter @ higher temp
    dloose is offline Cadillac Owners Member
    Automobile(s): 2009 CTS
    Aug 2009
    64
    44
    I had to go buy an 18" breaker bar and even then it took a massive push. The mating rim of the cap and the housing are pretty wide, like 3 mm, and think they sort of weld and thats what makes it difficult.
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    This happens a lot 18" breaker bar 6" extension and a 24mm and some force ccw always works its a pain to try and take it off with just a rachet wrench
  16. #14
    Stillrollin is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX AWD V-6
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    Probably get shot down for this, but I've been changing my oil on all of my vehicles for over fifty years and have yet to use a wrench of ANY kind to tighten the filter. I use chassis lube on the gasket and tighten the filters by hand. I have yet to have a leaker and yet, still have to use a filter wrench or a pair of water pump pliers to loosen them.
  17. #15
    tormented is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6 RW
    Nov 2010
    76
    Stillrollin, this thread is not about spin on filters, but a canister filter housing that has a screw on cap that needs to be removed to change out the filter element. I'ts the cap thats stuck preventing access to the filter......
  18. Remove Advertisements
