Cylinder numbers?
Results 1 to 6 of 6
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Cylinder numbers? in Cadillac SRX / XT5 Forums; Which side is 1,3,5? and which is 2,4,6? facing the engine form the front? Thanks...
    bloodchild is offline Cadillac Owners Member
    Automobile(s): 2004 SRX
    Jun 2010
    8
    Cylinder numbers?
    Thanks
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: Cylinder numbers?
    Someone more mechanically inclined can jump in here, but I believe the 3.6L V6 in the 04 SRX has the 1/3/5 cylinders on the right engine bank and the 2/4/6 cylinders on the left engine bank. So 1/3/5 would be on your left as you face the engine bay from the front of the car.
    I don't have the V6 but am pretty sure the V6 is mounted longitudinally (versus transverely) like a traditional rear wheel drive car.
    DetailByTony is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    34
    1
    PJ1520 is absolutely correct. I just used his information to diagnose a bad coil pack on my girlfriends 2004 SRX V6 RWD. The check engine light came on at the same time the car started running like garbage. Pulled the codes and got a #5 cylinder misfire. Swapped the #5 and #6 coil packs (using PJ1520's provided info) and sure enough it threw a code for cylinder #6. Thanks for the help. I love having information like this available, and hope I can help someone in the same way.
  5. #4
    Feb 2010
    New England
    2,005
    I traded a first generation 1998 Oldsmobile Aurora Autobahn for the SRX. Originally scheduled to be released as a Cadillac back in 1993-1994, it was rebadged as an Oldsmobile right before the original release to help the failing Oldsmobile brand. This car came with a destroked 4.6L V8 Northstar engine whose displacement was 4.0 liters. Replacing the (failing) coil packs one at a time was an exercise in futility for those who had the car and experienced misfires.
  6. #5
    99accordguy is offline Cadillac Owners Member
    Automobile(s): srx
    Mar 2013
    cadillac srx v6 - cylinder locations...
    5 6
    3 4
    1 2
    looking fron front of the car... so 1/3/5 is on the passanger side of the car 1 being by the left headlight and 5th being upper most toward the windshield. hope that helps.
    just had cyl 5 misfire.. changed coil \all plugs and now changed the fuel injector on 5th cyl and same thing.. same code flashing and engine misfirin p0305. any suggestions ?
    5 6
    3 4
    1 2
    just had cyl 5 misfire.. changed coil \all plugs and now changed the fuel injector on 5th cyl and same thing.. same code flashing and engine misfirin p0305. any suggestions ? its 2006 3.6 rwd
  7. #6
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,783
    99, Check this-
    A misfire DTC could be caused by a camshaft actuator stuck in the full advance or retard position.
    Been fixin' cars for 74 years
  8. Remove Advertisements
