04 SRX Turn Signal Replacement (Front) - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 04 SRX Turn Signal Replacement (Front) in Cadillac SRX / XT5 Forums; Just replaced one of the bulbs today. I made sure to replace the socket as well. It's dirt cheap. The ...
  1. #16
    PbPedis is offline Cadillac Owners Member
    Automobile(s): 2008 SRX AWD V6
    Jul 2008
    21
    Re: 04 SRX Turn Signal Replacement (Front)
    Just replaced one of the bulbs today. I made sure to replace the socket as well. It's dirt cheap. The job really isn't that bad overall, but considering it is just a bulb replacement, it is somewhat ridiculous. I can't imagine paying the dealer 1-2 hrs labor to change a bulb. Caddy owners will become ex-Caddy owners if they keep this up.
  2. #17
    TimRSRX777 is offline Cadillac Owners Fanatic
    Automobile(s): SRX
    Feb 2013
    126
    Is it just the 2006 sockets that are a problem or are other years problematic also?
  3. #18
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    335
    I just did this over the weekend. Holy crap that was interesting. Thought I might be able to do it without taking the wheel off but it's just so much nicer without it in the way.
    And it seems I have the ultra cool special headlamps, which I thought I just had standard but the standard turn signal bulb didn't fit in there. I thought I would just change both sides out but forget that. I'll just wait for it to burn out. should be only a month or two
  5. #19
    Whiplash_89's Avatar
    Whiplash_89 is offline Cadillac Owners Fanatic
    Automobile(s): 04 SRX V8 AWD, 04 NSRT4
    Nov 2012
    Windsor, ON
    223
    ^Haha. I just did mine too last tuesday. I did it withthe wheel still on there. It took a good 40 minutes. Mostly because I just cut those retaining clips off since I have extra ones and I didn't need to reuse them. I top left screw was a PITA...needless to say that one did not go back.
  6. #20
    OakSRX04 is offline Cadillac Owners Member
    Automobile(s): Cadillac 2004 & 2009 SRX V6 AWD
    Dec 2008
    Oakville, Ontario, Canada
    29
    Even the 2009s have the same problem. Just changed the passenger side yesterday with a new socket and a little dielectric grease on the contacts. Dealer did the same side under warranty about a year ago. Don't know if he replaced the socket. I doubt it.
  7. #21
    Mr. Mohr's Avatar
    Mr. Mohr is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V8 AWD Luxury Performance Package (Moonstone)
    Apr 2013
    Andrews AFB, MD
    93
    I had to replace my driver side. After doing all the work to get the old one out, I found out that they sold me the wrong one. So I had to put it back together to go and exchange it. Secong go around, I removed the air filter box and went in from the top. It looks like it would only work for the driver side. You could try and do the same with the passenger side. Maybe if you removed the fuse box somehow??? Who knows.
  8. Remove Advertisements
