Hesitation then Surge When Accelerating from Standstill
Results 1 to 10 of 10
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Hesitation then Surge When Accelerating from Standstill in Cadillac SRX / XT5 Forums; I have an '04 SRX V6 and within the last month, you press the accelerator from standstill and it hesitates/whirs ...
    mhousealum is offline Cadillac Owners Member
    Aug 2004
    Atlanta
    31
    I have an '04 SRX V6 and within the last month, you press the accelerator from standstill and it hesitates/whirs and then sorta surges into acceleration. It's only in first gear and only from a standstill. It seems to have gotten worse over the past month. I'm going to take it to the dealer on Monday but wondered if anyone has any ideas so I can cut down on my diagnosis time. I don't think it's the gas cause it's not a knock/ping. I'm wondering if it's the trans...thanks for your help.
    algiorda's Avatar
    algiorda is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 , 2010, 2014 Luxury Raven Blk w/Ebony
    May 2008
    Tampa, FL
    649
    Re: Hesitation then Surge When Accelerating from Standstill
    This sounds like the torque converter. I believe there is a TSB on the shudder problem with this year model. I have the same year, and mine shudders at 2000 rpm under load; but not all the time.
    bbeverly is offline Cadillac Owners Member
    Feb 2005
    What did you find out from the dealership?
    mjk
    mjk is offline Cadillac Owners Fanatic
    Automobile(s): 04 srx v6
    May 2006
    RICHMOND, VA
    38
    203
    I have the same problem with my 04 V6 87k mi. took it to the dealr twice and wouldn't do it there. It does it a lot but not all the time. Hope to get it resolvet before GMPP runs out.
    It happens more often when turning and up hill, but also happened on flat road going straight.
    Drives me crazy!!!
    mjk
    May 2006
    RICHMOND, VA
    38
    203
    Quote Originally Posted by algiorda View Post
    I think this is some other issue. The shudder happens while costing down to a stop not accelerating like th OP described. Is that what you have going on?
    mjk
    May 2006
    RICHMOND, VA
    38
    203
    anybody else have any comments on the surge/acceleration issues???
    mjk
    May 2006
    RICHMOND, VA
    38
    203
    just bumping it
    bfreeman Guest
    I'm having the same issue with my O4 SRX V-6 with 80k miles on it. Wondering if there's been anymore discoveries on this issue?
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,037
    It was not indicated when the last tune-up was done. While the sparkplugs may not yet be at end of life, the plug cables may be. The issue could also be a clogged fuel filter, which is messy but easy to fix.
    celianjr00's Avatar
    celianjr00 is offline Cadillac Owners Member
    Automobile(s): '01 Deville and '04 SRX
    Apr 2008
    10
    it's your timing chain tensioner. best bet is to do it all (timing chains (3)), cost me $700 to do it myself. the dealer wants $2400 to do it.
  13. Remove Advertisements
