Rough Starting
Results 1 to 4 of 4
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Rough Starting in Cadillac SRX / XT5 Forums; On three widely-spaced occasions, I had trouble starting my 05 V8 SRX. It would fire, then run very roughly, sometimes ...
    Fyreman235 is offline Cadillac Owners Member
    Automobile(s): 2005 SRX n* lx/perf
    Mar 2006
    Western Illinois
    76
    99
    Rough Starting
    On three widely-spaced occasions, I had trouble starting my 05 V8 SRX. It would fire, then run very roughly, sometimes quitting and having to be restarted. On one occasion, it started in my garage, rumbled and shook, emitted a huge cloud of smoke, and then ran smoothly. In each case, it eventually smoothed out with no further problem. One time I had to restart it a dozen or so times, but fortunately the battery held out and it took off. It has nearly 70k miles and has never been tuned up. Any ideas? Injectors? Ignition????
    jsiddall is offline Cadillac Owners Fanatic
    Automobile(s): 09 SRX V8 AWD Sport, 06 STS V8
    Oct 2009
    Ottawa, Canada
    43
    159
    Re: Rough Starting
    Sounds like something seriously wrong with the mixture, which is not likely injectors or ignition. What you describe is more likely an air sensor or perhaps something with the throttle actuator. Hopefully someone else has some experience with your symptoms and the resolution.
    Mar 2006
    Western Illinois
    76
    99
    Re: Rough Starting
    Thanks. I hate to take it in when it is running fine, and the problem does not last long enough to take it in when it is failing. Maybe it dropped a code for the scanner.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    41
    4,023
    Re: Rough Starting
    I already had a thread up with the same issue with my N* SRX.
    No cure yet as is is planned for workshop. They have been notified.
    Also have check engine light up. Codes have been diagnosed for bad catalystic converter. I hope both issues are related and solved with one fix.
    http://www.cadillacforums.com/forums...old-start.html
    http://www.cadillacforums.com/forums...codes-cat.html
  7. Remove Advertisements
