Tire pressure?
Results 1 to 3 of 3
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Tire pressure? in Cadillac SRX / XT5 Forums; Just got new tires yesterday. Put 4 Brigestone Dueler H/L Alenza 235/65R17 on all 4 wheels. I asked the guy ...
    Djacobs64 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2006
    44
    Tire pressure?
    I asked the guy at the tire shop how much pressure should I put in these tires and he said to put what the door panel says which is 32psi but the tire says 35psi.
    He said 35psi was the max tire pressure that's put on the tire.
    Should I go with 32psi like the door panel says?
    Thanks!!!
    louisn's Avatar
    louisn is offline Cadillac Owners Fanatic
    Automobile(s): 2004 srx V-8 awd
    Jan 2005
    arkansas
    482
    Re: Tire pressure?
    Cadillac recommends 32 in back and 30 in the front for my V8 with 18's. I usually add 2 lbs for gas mileage.
    Shane86 is offline Cadillac Owners Member
    Automobile(s): 04 SRX-4
    Feb 2010
    30
    7
    Re: Tire pressure?
    I put 36 all around. rides a little rougher, but helps mileage and helps protect the wheels from all the HORRIBLE potholes up here in mn.
    it also aids in steering response on these stock 17" wheels.
