2004 SRX V6 AWD poor MPG
Results 1 to 7 of 7
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2004 SRX V6 AWD poor MPG in Cadillac SRX / XT5 Forums; My 2004 V6 AWD SRX has started to get real bad gas mileage within the past 6 months. I use ...
    Djacobs64 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2006
    39
    My 2004 V6 AWD SRX has started to get real bad gas mileage within the past 6 months. I use mid-grade fuel (87) and always get recommended maintenance done. My mileage is at 52K.
    I know this vehicle only gets 16-22 gas mileage but I've only been getting about 13.
    Any suggestions?
    My next step is to get a diagnostic done.
    Thanks!!!
    b4z
    b4z is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Standard SrX grey/black 2006 GTO
    Mar 2003
    Chas. SC
    54
    1,795
    Re: 2004 SRX V6 AWD poor MPG
    Is your air filter clean? Could it be Winter gas causing the mileage to go down? I'm surprised you get the mileage you posted. Especially with the AWD models having the 3.91 gears. 15-22 is pretty good.
    I'd take it in for a diagnostic if you can rule out the gas being the issue.
    have you used gas that contains no ethanol?
    zardoz is offline Cadillac Owners Member
    Automobile(s): 2004 srx
    Dec 2009
    14
    Check your tire pressure. Add a bottle of Redline fuel system cleaner and a tank of 93 octane.
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    I need to go back and see what the ethanol content is up my way. It was 10% by volume as printed on the pump a few weeks ago, and ethanol by definition provides poorer gas mileage. I agree with the others. Try the easy stuff first.
    The gas: 87 is regular, not midgrade, the lowest octane available in my neck of the woods, and is the grade you are using. 89 is midgrade. And my V8 recommends 93 though it can run on a lower octane, pretty sure. Using a higher octane than what is recommended will do nothing to increase fuel economy.
    The lower tire pressure, a dirty air filter, and cleaner injector will all contribute marginally to fuel economy.
    Put those five things together and you may be relieved within a week! Then the mileage will put you with the rest of us......the SRX is no Honda Civic, a thirsty beast.
    Jack
    b4z
    Mar 2003
    Chas. SC
    54
    1,795
    With all 3 of my SRXs low tire pressure will kill gas mileage. easily a 1mpg loss if they are ar 26 lbs or so. My last 2 SRXs were delivered with less than 27lbs of air. One of them i drove for several months with the pressures like that.
    Took one of them on the tail of the Dragon and was wondering why it was understeering so much. LOL.
    Jake's SRX is offline Cadillac Owners Member
    Automobile(s): 09 silverado CC,SRX (N*), 07 Silverado crew 4X4, 2000 Impala
    Feb 2009
    54
    86
    I hear it should say 10% or so! I hear seafoam does wonders!
    tonygxp's Avatar
    tonygxp is offline Cadillac Owners Fanatic
    Mar 2007
    TomsRiver, NJ
    119
    get car scanned. may be a slow reacting sensor, not enough to trip engine light..
  10. Remove Advertisements
