04 SRX Check Engine light ????
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 04 SRX Check Engine light ???? in Cadillac SRX / XT5 Forums; Hello - This site is great. Just signed up and love it. I bought an 04 SRX 4.6 AWD yesterday. ...
    04-SRX-NH is offline Cadillac Owners Member
    Automobile(s): 2004 SRX
    Mar 2010
    44
    45
    I bought an 04 SRX 4.6 AWD yesterday. The carfax was clean as can be and the car seems to be very well cared for. I filled the gas yesterday with Mobile 93 octane and went for a inspection sticker. Got the sticker with ease and 10 minutes later the check engine light comes on. The funny thing is the same thing happened to my truck ten minutes after I got the inspection sticker for that.
    Can anyone tell me how to reset the check engine light ?
    Thanks in advance, Phil
    nstar is offline Cadillac Owners Fanatic
    Automobile(s): 99 Eldo ETC 04 SRX V8 AWD 13 XTS
    Jan 2005
    202
    Re: 04 SRX Check Engine light ????
    Check gas cap to make sure it tight. You will have to go thru several start cycles to clear light unless you want dealer to read codes and clear.
    Fyreman235 is offline Cadillac Owners Member
    Automobile(s): 2005 SRX n* lx/perf
    Mar 2006
    Western Illinois
    76
    99
    I had a check-engine that was intermittent and eventually became solid. It was diagnosed as bad catalytic converters, and they were both replaced, fortunately under the cpo warranty in spite of 70k miles. I hope that the gas cap solves your problem. I don't know if the converters are part of the power train warranty or not, but they could be expensive.
    thunderbyrd01 is offline Cadillac Owners Member
    Automobile(s): srx
    Jan 2009
    44
    Very well could be the gas cap, I've experienced that one, just remove the cap and place it back snug, also if you dont have a diagnostic scanner you can swing by Autozone or Advance Auto Parts and they will read the code at no cost but I'm fairly sure the light has to be on at the time they plug your car in to the diag scanner. If its running fine it probably isnt anything too major. Could it have anything to do with the grade of gas you used if it had previously been getting 87 ? I dont know if that would do it, just asking.
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    814
    If you have an active onstar account they can tell you the likely cause. My only experience using this on another vehicle they wouldn't give the actual code but "suggested" I check the gas cap. I generally turn it 3 clicks but for some reason hadn't on the last fill.
    Many have bought codes readers so you can do your own checking. Once a trouble code is set it's stored in the history of the ecm, even if the light goes out, and generally doesn't clear until a certain number of fault-free cycles have occurred. Some of the code readers can read what's stored in the pcm's history.
    It is strange it happened twice after the inspection. What did you determine the cause for your truck's problem?
    Paulie Walnuts is offline Cadillac Owners Member
    May 2007
    here you go - get to an Autozone parts store - give the kid a couple bucks as a thanks - they'll check your codes for free. True story - 136K miles - got an oil change at Mobil (1st time not at the dealer) 2 miles down the road my 1st check engine light. Autozone clerk pulled the code - realized it was a vacumm hose not reconnected under the air filter. He reconnected it. Done deal.
    Mar 2010
    44
    45
    Thanks so much for the replys. I went to AutoZone and It was a Mis-Fire which they said could have been from sitting a couple months. I put some fuel injector cleaner in it and it's been fine ever since. Thanks again
    I always use 93 octane also.
    XTSman is offline Cadillac Owners Member
    Automobile(s): 2013 XTS4
    Dec 2004
    58
    This has been said, so you will probably get from more than me... you can use 93 octane if you choose, but the 04 NorthStar is designed to run on regular gas. There are plenty of active threads on this, but my take on this is... you are pouring extra pennies, dollars down your tank instead of in your pocket. my 2 cents...
  11. Remove Advertisements
