Engine shutter on long Grade
Results 1 to 10 of 10
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Engine shutter on long Grade in Cadillac SRX / XT5 Forums; Hi I have a 2005 SRX V6 AWD. Lately on a long grade the engine( or it feels like the ...
    Caper10 is offline Cadillac Owners Member
    Automobile(s): 05 Cadillac srx
    Feb 2008
    19
    Hi I have a 2005 SRX V6 AWD. Lately on a long grade the engine( or it feels like the engine) will shutter or buck. It feels similar to the defective cat converters I had replaced about a year ago, but they are no codes. It almost feels like the engine is missfiring, or the torque converter. When the transmission down shifts the shuttering goes away. Looking for similar experiences or help narrowing down problem to the engine or tranny.
    Thanks
    Mike
    CBrady001's Avatar
    CBrady001 is offline Cadillac Owners Member
    Automobile(s): 2003 DeVille, 1999 Escalade, 2005 SRX
    May 2008
    Gaithersburg MD
    27
    Re: Engine shutter on long Grade
    Same problem here in my 05 V6
    OakSRX04 is offline Cadillac Owners Member
    Automobile(s): Cadillac 2004 & 2009 SRX V6 AWD
    Dec 2008
    Oakville, Ontario, Canada
    29
    Cadillac Forums: engine-transmission vibration at 38mph/1900rpm
    Check out the above thread and my experience.
    CBrady001's Avatar
    May 2008
    Gaithersburg MD
    27
    Cant find that thread
    JD2004 is offline Cadillac Owners Fanatic
    Automobile(s): Base 2007 Escalade EXT, 04 Cadillac SRX V8
    Sep 2007
    Oklahoma
    271
    From own experience and what I have read on this forum, the shudder probably relates to your torque converter locking up/disengaging. A transmission flush and semi-synthetic ATF has been the "cure" for some SRX owners. Might be a good place to start.
    Kauai 1 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX Lux; 2013 XTS Lux
    Jun 2006
    116
    Caper10, there are many discussions of the transmission shudder problem, posted over the past five years. The usual "cure" was a reflash and/or torque converter replacement. There is at least one TSB covering the problem.
    Be careful in changing the trans fluid; many recommend a drain and filter replacement, NOT a flush. And the proper spec fluid is Dexron VI.
    Feb 2008
    19
    After about a month of the shutter it finally threw a code on a 4 Hr haul home last night. PO302 Cylinder 2 missfire. I'm suspecting the coil. I haven't had a chance to look at it yet, i'm going to pull the sparkplug and look at the wires and coil. Any other suggestions?
    thetobins's Avatar
    thetobins is offline Cadillac Owners Member
    Automobile(s): 07 escalade ext/ 04 srx awd
    Feb 2010
    45
    61
    Had the exact same thing happen on my 2500k trip home from the dealer after purchase. Long grade engine felt like it was stalling, this occured a couple of times and the engine light would flash then tranny would downshift and problem would go away. I assumed car had been sitting up for a while on the dealer lot and it was dirty injectors, added some cleaner at the next pit stop and it has cured the problem, or so i think! Dealer has called to offer warranty @ $1600.00 for 3yrs. it's an 04 v6 awd, think i should buy it? Powertrain, awd and all seals are covered.
    thunderbyrd01 is offline Cadillac Owners Member
    Automobile(s): srx
    Jan 2009
    44
    I drive a 05 SRX and I experienced the exact thing a few months ago. At first the check engine light would come on and blink only during the hesitation or bucking, as soon as the road leveled off the engine light would go off, it took several weeks before the light would stay on. I had the exact same code you do. I replaced the coil pack on that cylinder & problem solved. Good luck, and let us know how that turns out.
    Feb 2008
    19
    I changed the coil on #2 Cylinder a couple of days ago. It seems OK now but I'll see for sure when I get on a long run later this week. It wasn't too bad to change except for moving the upper intake manifold out of the way. The new coil was $85 for an aftermarket unit.
  13. Remove Advertisements
