Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac SRX Forums > Cadillac SRX First Generation Forum - 2004 - 2009
Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
cadillac-srx
Cadillac Forums: 05, Transmission Hot Idle Engine
Old 11-07-09, 09:33 PM
Cadillac(s): SRX (N*), 07 Silverado crew 4X4, 2000 Impala
View Jake's SRX's Photo Album
Casino Cash: $3880
SO we purchased the 2005 N*AWD Feb 09 and it stayed in the garage (except for the odd drive to ensure it didn't forget what it was supposed to do) it had 55K miles and started it;s daily use 3 months later. Had an issue in july with the torque converter and it was replaced. However there was issues in getting one so we ended up driving the truck for about 1800 miles on the bad converter. when they changed it Aug 7, 2009 we had them service the transmission since the TC work was being done . So last Saturday we were out for a shopping trip (short drive maybe 50 miles one way) and on the way home we had some stop and go driving and had the transmission hot idle engine come over the DIC, so we let it cool off and continued. Thought nothing off it just odd. So today we did the same trip today and guess what, same stop and go driving same DIC warning on the tranny temp. No sport shifting just normal slow down rearly stop then speed up driving due to volume on the road.
Do you think that the 1800 miles we put on it with the bad torque converter(TC) is coming back to haunt us?
We were instructed that the BAD TC would not affect the health of the transmission. So we do have GMPP and pretty sure the repair will be covered but we purchased this unit because one of the things we were told was we would get easily 120K miles out of this vehicle. I don't doubt that but I guess we should have asked at what cost???
Are we being to critical thinking that replacing a TC and 3 months later looking at a transmission is to much? We like the truck but common what will be next.
Well it goes in to the dealer probably Tuesday for them to look at it and do the diagnostics. My diagnostics is sloppy shifting, vibration at about 1950 rpm, sport shifting not working correctly, the downshift when in drive is abrupt at times , shift from 2 to 3 is somewhat harsh not enough for whiplash. Please give me your insights.
  #2 (permalink)
Old 11-08-09, 07:15 PM
Casino Cash: $3880
Re: 05, Transmission Hot Idle Engine
More info for this, the transmission oil life is down to 88% with just 2400 miles on the new oil and filter. what is this sensor looking at? Does it sense impurity or engine starts?
  #3 (permalink)
Old 11-09-09, 09:14 AM
Spyke's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2005 Cadillac CTS 3.6L VVT
View Spyke's Photo Album
Casino Cash: $16773
It only means one thing, when they changed the transmission fluid, they didn't reset the OLM, simple as that!
I think, forgive me if I'm wrong, but I think its looking at vehicle loads, transmission fluid temperature, maybe time of use...
I'm more familiar of the Oil life monitor for the engine oil than the transmission fluid.
  #4 (permalink)
Old 11-09-09, 11:40 AM
Cadillac(s): 04 SRX AWD V8
View conedoctor's Photo Album
Casino Cash: $9105
This used to happen to us in an 03 Duramax pulling the trailer on a hot day.
So that being said what can cause temp in the tranny?
Lack of oil
Lack of oil flow
Wrong oil
Cooler airflow
Excess load on the car (but this would show up and slugish and bad mileage)
If the oil life is dropping fast maybe it is just seeing high temps all the time and it is coming down fast, ours is at about 70% and we have 55k on the odo.
  #5 (permalink)
Old 11-09-09, 07:44 PM
Casino Cash: $3880
Thanks for the replies, I know the TOLM was reset in Aug. Not pulling anything But I did gain 10 lbs over the summer but don't think that's it. I cant check the level so I will trust when they look at it they will tell me the real level.
What's your thoughts on the driving with the Bad TC , could this have effected the tranny?
Nothing blocking the cooler...
Thanks again for the replies, it off to the dealer tomorrow.
  #6 (permalink)
Old 11-18-09, 08:27 PM
Casino Cash: $3880
Update:
It is at the dealer as of this past Monday evening. The service adviser called me to let me know that it appears the thermostat in the transmission oil system is defective and needs replacement. we were cut short so I couldn't clarify what they found as the cause. he said they are dropping the pan tomorrow to replace it.
Any Transmission GURU's here? Would the Torque Converter failure send bits through the transmission?
Tags: , ,
engine, hot, idle, transmission
