Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac SRX Forums > Cadillac SRX First Generation Forum - 2004 - 2009
Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
cadillac-srx
Cadillac Forums: annoying creeking near sunroof
  #121 (permalink)
Old 05-16-08, 02:22 AM
Cadillac(s): Cadillac SRX (05)
View Starvin48's Photo Album
Casino Cash: $300
Re: annoying creeking near sunroof
...chalk me up for the same issue. Love the vehicle; hate the squeaky, glorious, annoying, incredible ultraview roof. I hope somebody someday remedies that issue.
  #122 (permalink)
Old 05-16-08, 01:23 PM
bond2's Avatar
Cadillac(s): '07 SRX V8 AWD 20" Sport
View bond2's Photo Album
Casino Cash: $3930
It's all related to cold weather. As soon as the temps drop below 40 degrees mine starts to make the creaking/rattling noise again. Now that its warmer I have absolutely no noises from the Ultraview. The cold weather must cause the metal in the ultraview housing to expand/contract and then rub up against something to cause the noise. I have an issue with my 1996 Trans Am, where in the winter my front door rubs against the side panel when I open the door, it gets really bad and I have rubbing marks to prove it. Once again, once its 40+ degrees out the rubbing ceases to be an issue. Really kinda weird. Makes you wonder how much cold weather testing GM is doing for the body panels and such related to the expansion/contraction of the metal they use in our cars.
  #123 (permalink)
Old 05-16-08, 02:54 PM
View jsportel's Photo Album
Casino Cash: $450
I am new to this forum but share many of the same problems . I live in Port Elgin Ontario Canada and bought my 04 SRX in Florida in Jan. 08 the noise you describe is identifeid in a TSB #06-08-67-012 The parts to fix this is cheap .....(40.00) but the time in the shop is what will give you a heart attack it was 12 hrs labour at 90.00 bucks an hour as they have to remove the roof liner and that is what takes the most time.
  #124 (permalink)
Old 05-31-08, 09:52 AM
Rob_L's Avatar
View Rob_L's Photo Album
Casino Cash: $415
My '06 SRX has this creaking sound too. sounds like two plastic panels rubbing together. It doesn't matter if it is cold or hot (32-90 degrees F). Seems to be worse when the sunshade is retracted. I have silicon lube sprayed all tracks and parts I can get to. seemed to have helped for a day or two.
Dealer says they found a TSB but did cite the number. They are ordering parts. I will report back when I have more info on fix or no fix.
At least they are making an effort to try and resolve this common problem. Luckily I still have some factory warranty left.
Rob
  #125 (permalink)
Old 06-01-08, 10:11 PM
View Bill Brummett's Photo Album
Casino Cash: $460
The problem is with the original design tracks for the Ultra-View. Had the same problems with my 04. After about 3 unsuccessful tries by the dealer to remedy the problem, they looked a little deeper and found that there was an "unpublicised" fix by GM. Involved totally replacing all of the tracks and clamps with a different design. After this mine is TOTALLY silent, warm or cold.
Ask your dealer to check this out.
  #126 (permalink)
Old 06-02-08, 07:48 AM
Rob_L's Avatar
Casino Cash: $415
Bill:
Thank you for your reply. My dealer said he is ordering "parts". They should be in by the end of this week. I will print out your reply and take it with me and inquire what parts they ordered. When did you have your repair made? I wonder if the new design was implemented in the '06 and my creak is due to something else. I doubt it, but I am obliged to let them try their fix if it involves parts other than the tracks and clamps you mentioned.
Rob_L
  #127 (permalink)
Old 06-02-08, 05:04 PM
Casino Cash: $460
Rob...
As best I recall, it was about a year ago. Mine is an '04.
  #128 (permalink)
Old 06-03-08, 07:34 AM
Rob_L's Avatar
Casino Cash: $415
Thanks again for your reply. I will report back to this forum on my success, or failure to have this pesky noise eliminated.
Rob_L
  #129 (permalink)
Old 06-11-08, 02:25 PM
Casino Cash: $450
There is tech service bulliten #06-08-67-012 that adresses this problem cost me upwards of 750.00 cdn dollars to fix ths as it requires alot of man hours to fix.
  #130 (permalink)
Old 06-12-08, 12:08 PM
Rob_L's Avatar
Casino Cash: $415
Re: annoying creeking near sunroof- update, almost
Thanks for the TSB number
I just got notice from my dealership that the parts they orders are in to hopefully fix this problem.
I will report back on any success... or failure.
The creak went away in this 90+ degree weather, but it came back last night when the temp went back down to mid 70's and I travelled over some bumpy roads.
Rob_L
  #131 (permalink)
Old 06-17-08, 12:26 PM
GMJim's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1980 Coupe Deville, 1990 Eldorado, 2006 SRX
View GMJim's Photo Album
Casino Cash: $11587
The best remedy I have found is to utilize your Bose system to the max.
I hear no creaking.
  #132 (permalink)
Old 11-22-08, 05:00 PM
View Snowbird's Photo Album
Casino Cash: $300
I have a 2007 SRX and had the same problem. Took it to the dealer and they basically pulled the head liner down and foamed everything they could. It did stop it but they were going to try and break the welds and re weld it. Not a good idea but they didn't have to do that. Anyway, it's fixed. The problems I have had are as follows: Timing chain, new steering box, turned the rotors at 30000 kms or 20000 miles. Now the battery keeps going dead after 3 - 4 days of sitting in the garage. any body had these problems?
  #133 (permalink)
Old 03-21-09, 03:57 PM
Cadillac(s): 2000 Seville STS
View Bev1's Photo Album
Casino Cash: $250
Re: Annoying creaking near sunroof
We have a '94 SRX with the same creaking problem in the sunroof. It's a real turn-off, isn't it? But we've asked around and it appears that the problem is the rails that the assembly rides on. It should have been a recall, but I guess, with all the money problems that GM is having, it isn't in their budget. Our understanding is it can be fixed, but it involves replacing the rail assembly which will cost you about $500. Is it worth it, not for me right now. I love everything else about the car, so unless the creak stops me cold in the middle of the road, I'll live with it for now.
  #134 (permalink)
Old 03-21-09, 06:31 PM
View srx05v8's Photo Album
Casino Cash: $1760
my 05 is quiet as the weekend downtown Detroit... My only problem with ultraview is that my 2-year-old daughter gets scared when she rolls her eyes up and sees her own reflection in it...
  #135 (permalink)
Old 03-22-09, 10:29 AM
Rob_L's Avatar
Casino Cash: $415
Thanks for the added info. I have owned my '06 for a year now. It seems that the creak is worse in cold weather. Dealer tried to fix it last summer and it went away until winter. I have avoided going back in because they did "fixed" what they were able to glean from TSB's. With this new info about the rail assembly I will go back in with this info and see what they say. I am still under warranty so it shouldn't cost me anything but time and inconvenience.
Otherwise I have had no other problems and have enjoyed this car.
rob_L
Tags: , , ,
annoying, creeking, sunroof
