Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac SRX Forums > Cadillac SRX First Generation Forum - 2004 - 2009
Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
cadillac-srx
Cadillac Forums: 05 SRX chuggle at high way spend under light load
Old 03-20-09, 02:55 PM
Cadillac(s): srx
View thunderbyrd01's Photo Album
Casino Cash: $1255
Anyone else out there ever experienced this ? What did you have done ? Did it correct it ? Need some help guys, my 05 "chuggles" (yes, that is the word GM uses) at highway speed under a light load. I've done a ton of research and Have come across a TSB that describes my problem accurately. The repair calls for the TCM to be reprogrammed. How is it done ? What cost can I expect ? Thanks in advance.
  #2 (permalink)
Old 03-20-09, 04:11 PM
Cadillac(s): Cadillac
View cfishkin's Photo Album
Casino Cash: $615
Re: 05 SRX chuggle at high way spend under light load
I don't know what that means exactly, but my 05 V6 AWD, seems to be slight holding back then normal, back and forth, at highway speeds. Is that what you are describing ?
  #3 (permalink)
Old 03-20-09, 05:02 PM
Cadillac(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
View n7don_srx's Photo Album
Casino Cash: $11849
A dealer will have the equipment to reprogram the TMC. The reprogramming typically is a software update to address a specific issue. So your best bet would get an estimate from them. I'd guess the charge would be under an hour but strickly a guess.
I'll default to others as to the effectiveness of the update. Occasionally the cure can be worse than the problem.
  #4 (permalink)
Old 03-20-09, 09:52 PM
mthake's Avatar
Cadillac(s): 2005 SRX rwd V6
View mthake's Photo Album
Casino Cash: $2180
I had the same, expected it to be the TSB you are speaking of, turned out being too low on oil. I know, its crazy, but an oil change later and everything is fine again. except for the excessive oil consumption.
  #5 (permalink)
Old 03-20-09, 10:05 PM
Cadillac(s): srx
Casino Cash: $1255
cfishkin: Kind of like a fouled out spark plug or maybe a stopped up fuel filter, the car runs great but climbing even a small incline, the car hesitates, and stutters
n7don : you said occationally the cure is worst than the problem, yes I have heard that about the ECM reprogramming or reflash. I'm wondering about that to, thanks
mthake: Funny you mentioned that because I read a thread on this forum saying the same thing, I changed my oil last weekend, while it did run much better I still have the prolem, thanks for your reply.
  #6 (permalink)
Old 03-20-09, 11:13 PM
c5 rv's Avatar
Cadillac(s): 91 Allante, 06 SRX (gone)
View c5 rv's Photo Album
Casino Cash: $17445
I have a bit of driveline chugging at 35-40 MPH under light throttle. It's not yet bad enough to take in.
  #7 (permalink)
Old 03-23-09, 07:39 AM
Cadillac(s): 2004 Cadillac SRX
View Autobahn_Burner's Photo Album
Casino Cash: $1517
I had it and I did three fixes: reprogramming transmission - replaced torque converter - replaced spark plugs. After that everything was fine. Transmission feels more old school "American" than it did before.
Keep in mind: after reprogramming - system does not allow to go back to original transmission mapping...
Good luck!
  #8 (permalink)
Old 03-26-09, 04:36 PM
Cadillac(s): 2007 SRX
View King3244's Photo Album
Casino Cash: $2605
I had my 04 transmission reprogrammed with the flash and it fixed the same problem and it cost 100 bucks at the dealer....(only place that can do it).
  #9 (permalink)
Old 03-29-09, 12:57 AM
Cadillac(s): 2004 Cadillac SRX V8 AWD
View George Ware's Photo Album
Casino Cash: $475
I had a bad coil and spark plug.........$582.10
George Ware
Tags: , ,
chuggle, high, light, load, spend, srx
