Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Rear Rotor Removal and Installation in Cadillac SRX Forums; Yesterday I changed the front rotors and pads on my 06 RWD. I moved to the rears to tackle them ...
- 11-21-08 09:45 AM #1
- Automobile(s): Cadillac
- Join Date
- Sep 2008
- Age
- 28
- Posts
- 2
Yesterday I changed the front rotors and pads on my 06 RWD. I moved to the rears to tackle them and got a little nervous. I can't tell, without removing the rotors, if the e-brake assembly is actually attached to the rotor.
1. Is the e-brake attached to the rotor or the hub assembly?
2. Do you have to remove the e-brake assembly to change the rotors?
3. If you do have to remove the e-brake assembly what is the procedure to remove and reassemble the e-brake?
Thanks
Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.- Join Date
- Always
- Age
- 2010
- Posts
- Many
- 11-21-08 01:27 PM #2
Re: Rear Rotor Removal and Installation
No, but the e-brake is pretty snug up inside the rear rotor, even when not applied. Use a rubber mallet and some elbow grease to pop the rotor off. Make sure you remove the mounting screw first. Good luck.
- 11-21-08 01:45 PM #3
- Join Date
- Sep 2008
- Age
- 28
- Posts
- 2
Ok thanks. I was scared that a spring or something would pop off from the e-brake.
| Sponsored Cadillac Advertisements (Supporting Members don't see these ads) | |
LinkBack URL
About LinkBacks
